Question about Toshiba Satellite A15-S129 Notebook
Pink screen on the laptop but when iattach an external monitor it works fine
  • Anonymous Dec 16, 2007
    I have dell d600 and my LCD white colr changed to pink....is it LCD needs to be changed or I can save money to replace some parts...pls suggest
    amit
    mail me: amitgupta008@yahoo.com
    Thanks
  • markland Jan 19, 2009
    My Toshiba A15-S1292 has similar problem except the screen is white and nothing on it nor change with any keys. Will work find with an external monitor plugged in, what can I do or check?
    Scholar:
  • 88 Answers
Pink screen is usually a sign of the backlight going bad. Does it go from pink to normal after a while? usually that is the ccfl warming up- but it will need to be replaced- either the whole lcd, or just the backlight (ccfl) part of it.
Posted on Nov 24, 2007
Toshiba satellite c55t pink lines on screen. Pls help my laptop screen colours have change. There is pink lines on screen as soon as u switch the machine on.
Faulty screen by the sound of it. Try on external monitor. If All OK on external monitor the screen is faulty.
Nov 17, 2014 | Computers & Internet
PINK Laptop screen
1. Plug in an external monitor to your laptop. If the picture on the external monitor is good, then the problem is your laptop screen. If the external monitor also displays a pink screen, the problem is in your laptop hardware or software.
  • 2 Contact Dell if your computer is still under warranty when the problem is with your screen. If your laptop is not covered by warranty, contact a computer repair shop to have the screen repaired or replaced.
  • 3 Update your drivers and bios. Outdated drivers or bios have been known to cause screen issues. Visit Dell's Drivers and Downloadsicon1.png website where you can enter your service tag and find the appropriate updates for your computer.
  • 4 Contact Dell's technical support team if the above steps do not fix the pink screen. Dell has had known issues with the pink screen being caused by the graphics card on some of their laptopsicon1.png. In many cases, replacing the motherboard is necessary to remedy the problem.
  • Read more: http://www.ehow.com/how_6318059_fix-pink-screen-dell-laptops.html#ixzz2n6yCxzw5
    Dec 10, 2013 | Dell Latitude E5500 Laptop
    Pinks squares on Dell laptop screen
    Try connecting to an External Monitor via the VGA Port, if Ok on a known good monitor then ONLY the Screen is faulty, if pink squares show up on the external monitor than video chip (Graphics inside the Laptop and on the Motherboard OR cable from motherboard to Screen, see how you go.
    May 01, 2013 | Dell Computers & Internet
    My Aspire 5670 screen is dead.
    Update the video drives, if that doesn't work replace the vga cable. If that doesn't work try it on another monitor.
    Jan 19, 2013 | Computers & Internet
    Pink screen
    If the pink lines or streaks are across the screen then this indicates the CCFL lamp will fail soon.
    To confirm it is not the video chip on the motherboard, connect an external monitor to your laptop, power up the monitor first and then boot up your laptop. The video will automatically divert to the external monitor and if the Windows image is normal then this confirms a problem with the CCFL lamp and it needs to be replaced.
    Sep 23, 2012 | Samsung N150 (36725723009) Netbook
    Lcd screen has pink tint
    Hi Friend, In this case I would recommend you to please connect any external monitor to the laptop and check if the same issue happens on the external as well.
    • If the external one also has the same pink tint then try and update the video drivers for the system.
    • If the external display is fine without any tint, then, I believe the issue is with the LCD of the laptop itself, you can try restoring the screen to factory settings and check if it helps.
    Otherwise, I would recommend you to please get in touch with the vendor itself.
    Please let me know if it was of some help.
    Thank you.
    Jan 06, 2011 | Acer Aspire 5610-4648 Notebook
    The comuter works but the screen is pink
    Chances are the video inverter is bad. have it replaced at your local shop or order the part online and replace it yourself.
    A good way to see if it is the screen itself is to plug in an external monitor into the VGA port on your laptop. Is the second screen pink or fine? If its fine you need a new inverter board.
    Oct 17, 2010 | Computers & Internet
    Pink dots on screen
    Could be try connecting to an external monitor using the vga port. If the same problem appears on the external display the problem is most likely the video card. You may wan to update the display drivers.
    Jul 27, 2010 | Toshiba Satellite X205-SLI1 Notebook
    Flicker
    if you have screen Flicker, this could be several Things. Faulty or Failing Inverter Board, Or tft screen tube failing ( usually determined by occasional Pink Screen At Startup ) try to use an external Monitor. if it,s fine on an external. this will eliminate motherboard or graphics chip fault.
    Mike @ compurepair.
    Sep 05, 2009 | Acer Aspire 4520-5803 Laptop
    I get pink spots on my laptop
    This is known as bleeding in LCD .you can try to update video drivers or try to connect external monitor (any normal desktop monitor) and see if same thing happens on external monitor then most probably it is the video card if on external monitor works fine then it is issue with LCD .if system is in warranty then get in touch with dell support
    Let me know if this helps
    Regards
    Sep 14, 2008 | Dell Inspiron 1501 Notebook
    Toshiba Satellite A15-S129 Notebook Logo
    287 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
