Whirlpool 8,000 BTU Electronic Window Air Conditioner - ACQ158XR
Problem for Whirlpool 8,000 BTU Electronic Window Air Conditioner -...
Whirlpool ACQ128XRO air conditioner kept tripping
By kristinurse on Jul 29, 2009
whirlpool ACQ128XRO air conditioner kept tripping the circuit breaker. Now the fan will not work on it.
Was this helpful?
Yes
No
Solution #2
posted on Jul 29, 2009
Not Rated)
airjoc
Rank: Guru
Rating: 90%, 225 votes
When it was running (working), did you hear the unit thermostat click on and off; was cold air comming out at all? Check capacitor may be faulty causing the unit overload and trip the breakers. Check the electronic control board might also be bad since the unit is not working. Bad motor can also trip the breakers before it burn out. Fan motor 60 bucks, capacitor 54 bucks and control boad 105 bucks. hope that help some.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool 8,000 BTU Electronic
Questions and Unsolved Problems for Whirlpool 8,000 BTU Electronic
Do you recommend Whirlpool 8,000 BTU Electronic Window Air Conditioner - ACQ158XR?
Answer
Answer
Gas heat does not always come on when it is switched on, when it does it works fine when it does... (More)
Answer
I have an Amana Gas Fired Furnace Model CCA24FCC. It recently started blowing cold air out of the... (More)
Answer
It has an arc protecting plug with a little green lite that shows power and a reset button. The... (More)
Answer
the display on my ac shows 89 when i turn it on and the compressor never kicks on. i turn the... (More)
Answer
extended uses causes the window unit to freeze up and restricts all airflow
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool 8,000 BTU Electronic...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
