Kyocera mita dc-1460 need parts
roller where paper comes out are melted and I need replacement parts.Where do I go?
    President:
  • 3,085 Answers
You might try to contact a Kyocera-Mita or Copystar Dealer in your area. But I don't think anyone will have those parts.
Posted on Jul 29, 2009
How do I darken copies?
Dear Eric Smith,
i think it is control pannel board issue is there....
Jun 25, 2014 | Kyocera Mita Toner for DC-1460 & DC-1470...
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.
Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.
The paper feed rollers may need cleaning or replacing.
Jan 03, 2012 | Kyocera Mita KM-2530 Laser Printer
MITA DC 1460 copier stops
try switching to "manual" exposure setting instead of "auto" call service to check sensor and process control
Jan 06, 2010 | Office Equipment & Supplies
Paper jammed between 2 red rollers in the back, can;t dislodge
The red rollers are probably replaceable, and therefore removable. Take a close look, and see if you can tell how they would be removed. It will either snap out, or you'll push it to the side and remove one end at a time. It'll be easier to pull the paper without the roller in the way.
While you have the roller out, you can clean it by wrapping packing tape around it a few times.
Jan 03, 2010 | Kyocera Mita FS-1920 Laser Printer
Kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Sep 18, 2009 | Kyocera Mita Office Equipment & Supplies
Kyocera Mita FS1010 fault
check your user guide... it will explain this error... or contact kyocera customer support...
Jun 25, 2009 | Kyocera Mita FS 1010 Laser Printer
Hi there i have fs kyocera 1000 and when i wont to print the printer tak the paper but the paper get empty and the printer stop .so i open the cover and close the printer resuom printing and the paper get...
clean the paper feed roller with a damp cloth after removing the paper tray, otherwise call a technician since parts may need to be replaced, including the roller in case.
Feb 26, 2009 | Kyocera Mita FS 1000+N Laser Printer
Auto paper feed jamming
clean the rollers with alcohol. this will renew the rubber and clear up the problem
Jun 27, 2008 | Kyocera Mita KM-2530 Laser Printer
Kyocera FS-1920 won't pick up paper from tray
replace pick up rollers and paper tray roller. Take out paper tray and toner, lift printer so you can see underneath you should see a set of rollers its nopt to hard to get out. also in the paper tray there is a roller swop that out to
Dec 14, 2006 | Kyocera Mita FS-1920 Laser Printer
201 people viewed this question
jasbo
jasbo
