Question about Kenmore Dryers
Replaced the heating element what ever its called. and still not heating up' its politless
    Scholar:
  • 44 Answers
Disclaimer: I don't know this particular model, but in general, tumble dryers have 2 or 3 interlock switches that need to be checked:
1. Door interlock: this allows the drum motor and fan to energise and the heating element to be turned on: Does drum turn and fan come on? If so, it is not this.
2. Overheat switch: located in exhaust path of fan: usually re-settable - have you located this and reset it?
3. Humidity sensor (some models have this, some work on time only) - this can fail open circuit and the drum and fan won't come on. (Same check as number 1)
Posted on Jul 29, 2009
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
I replaced the element in my 80 series dryer. Now the element continues to heat without the dryer running ! Any ideas?
Some were u got what call short to ground. It problem the motor are u got a wire touch the dryer cabin if u don't know how to check it u might won't call for service are when u put the element back in it case one of element heating coil is touching the case.
Apr 03, 2015 | Dryers
I have the euro steam blaster s3325 when I turn it on, the steam ready **** comes on right away not heating can the heating element be replaced? thanks
There is a device attach to the heating element called a thermo fuse, this devise brakes down when it get to hot.
open the machine and replace it with the same value. it is written on it..
Nov 20, 2012 | Euro-Pro S3325 Handheld Steam Vacuum
Heating elements in fan oven not working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 26, 2011 | Smeg Ovens
Oven won't heat
The heating element may be worn out or loose. Are both the broil (upper) and bake (lower elements) failing to heat? If so, you will probably need to call a professional. If only one of the elements is failing to heat, it will need to be replaced. This is usually a simple matter of tugging firmly on the element and it will slip out of its housing. Once you purchase a replacement element you just plug in back into the housing. You can buy the elements at appliance parts stores. I would suggest calling an appliance parts store and asking them IF you can remove the element yourself. If they know they're about to make a sale, they don't mind giving you the information.
Nov 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I need to replace the heating element. I've only had this smoker for 18 months and have not used it that much. I'm disappinted that I need to replace the heating element so soon.
it appears all the reviews i have read say that you cannot replace the heating element and they do not sell replacements , but from reading further many customers have been able to have the whole unit replaced . i would call customer support
http://www.masterbuilt.com/contact.html
Sep 28, 2010 | Masterbuilt 20070106 Electric Smoker
My heating element is not working. How can I get a replacement.
I experienced the same problem. My heating element was not working. After a Continuity Test, the Heating Coil was dead and needs replacement. I asked Masterbuilt if any heating coil replacement parts were available. They said "no", but they could offer a discounted sale on a new Smoker for about $175.00. I am still looking. A local appliance dealer said the internet was the most likely place to find one. After looking on the internet, I can't seem to find one yet. If you know of any, please let me know. Call (616) 772-1332 and ask for Bob. Thanks
Jul 10, 2010 | Masterbuilt 20070106 Electric Smoker
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
Won't heat
If it spins - you have a problem with the heating elements (usually they are 2 heating elements).I suggest you call a tech and have the deffective elements replaced
Apr 27, 2009 | Whirlpool LER4634J Electric Dryer
Frigidaire GLer642As3
A grounded element on an electric dryer is an element that has broken and the element heating wire has touched something metal, like the cage that is suppose to hold the element or the element metal housing around the element. What this does is, the element only heats on the section that is touching the metal part and usually this part of the element is only heating at about 1/2 heat output. An grounded element can also stay on even when the dryer is not in use!!
May 12, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
