Question about HP Compaq FS7600e CRT Monitor
Monitor Does not Work properly anymore
Thanks ahead of time for reading this. My monitor is less than a year old. I recently moved and had it shipped to my new address. The monitor worked before i moved without any problems of any kind.
However, when i got it here and finally got a chance to get it set up, the monitor itself will not turn on correctly. The monitor started to whir and click as if turning on and off. But now it will not even do that. The power cord works (i tested it with my tower, exchanging the two back and forth to check if it mattered but it did not seem to), but the monitor itself will do nothing.
My question basically is, is there anything that i can do myself to get this working. I cannot afford to purchase a new monitor and i cannot pay for repair fees. Please help me if you can.
    Problem Solver:
  • 5 Answers
The monitor was damage during shipment! On the monitor’s main circuit board, look for cracks, cold solder joints, especially around the big transformer (Flyback), Check the horizontal output transistor.
Posted on Dec 01, 2007
Gateway FPD 1730 (mfg June 2004) On start-up, monitor flashes bios screen for less than half a second, then flashes the Windows XP logo for less than half a second and then stays black, no image. No...
All support is finished for XP years ago. The system is 13 years old and well past it expected life. Average is 8 to 10 years on a shop bought unit like Gateway, 12 years on a custom build.
I am thinking you probably have a dry joint on the board behind the switch as holding the switch makes the monitor work.
My advice though is a new computer running Windows 10, technology moves on in hardware and software.
Mar 08, 2017 | Gateway FPD 1730 17" Flat Panel LCD...
Hotmcompaq 7020 monitor will often display the following when turned on... the 'title page' showing Compaq. Then a rectangle shows up that says "searching for analog signal" then few...
That is the OSD brain, inside said monitor
The On screen display , window.
push the menu key on said monitor, see that MENU now?
sure. that tells you the monitor is basically OK.
that message means the unstated PC, is not sending any video or sync signal (or its cable is bad or unplugged or loose)
or the funny timer is tripping.(out)
monitors evolved like 5 times from year 2000.
so first i carbon date yours, to see what you actually have.
FP7020 is not a TFT7020, got it.
i wish i could read the service tag on it so i can be accurate but i cant.
no matter both are now RETIRED. at HP (hp is compaq , a fact)
https://support.hp.com/us-en/retired-products
Zero support now... no books, no nutt'n!
the first monitors, had a timer inside, and a clock that had a auto sleep mode, inside it, yah. they did, and is a pain .
lacking the book , one cant know that can one.
seems its 2002 carbon dated. wow 15 years young , ouch
this is the year the VESA rules went in to effect.
long ago, and changed 4 more times. dig>?
found a 15 years old product sheet on this old display
shows"internal sleep timer" yup, I just knew it was there,....
first make sure its off. (this must be OFF)
if its on and the clock inside is set wrong, it will trip off , at odd times.
let me explain back in the dark ages of monitors.
they had many PC that had no sleep mode
so HP(old compaq) put a clock(time of day) and sleep timer in dislplay., (for US gov, energy STAR bs)
so what you do is first set the OSD clock to the correct time.
then in the same menu system turn off the magic clock.
magic is that only this old junk has this display
or
test the monitor on another pc to see if its monitor issues or not.
lets not say , the monitor , is ok, and its funny INANE sleep timer is shut off.
what next, well the PC is next.
but wait you never told what PC, ?
so it can be any of 10,000 different models , VGA cards, chips and OS.
endless possibles for 36 years of PC evolution.
hopeless on my end to speculate.
NOr did you say what OS you are running.+
All PCs shipped new have shipped with sleep turned on in windows
or is this running OS2 or LINUX.
in WINDOZ
click control panel
there click power settings
there, click custom settings and give it a name, and then pick
NO sleep, no Hibernate at any time.
then turn off screen savers if on. most are off default.
when the PC wants to sleep it stops the Sync lines on the VGA card
or GPU chip.
the monitor sees that and goes to sleep. all do.
if the card is bad, its bad.
if OS is corrupted reload it.
if the PC runs ok on other monitors you cable is bad.
if the cable is ok the and PC is ok, then the monitor is bad
simply move the monitor to other PC
simple move pC to other monitor, and 1/2 the possibles are now know... in 15 min work, about.
Jun 24, 2017 | Compaq FP 7020 17" Flat Panel LCD Monitor
I have an L2410NM (24"vis,
I have this same monitor with the same exact issues. It is the control panel of the monitor starting to give out. The monitor will work better with some video cards than others, it has to do with the video signal coming from your 9800GT. For example if you switched to an ATI based card the problem may very well be less frequent, it was for me... but it most likely will never go away completely. However switching from an Nvidia to an ATI card made the problem go from happening daily (multiple times a day in my case) to more like once a week, sometimes less.
You probably have had the two working in conjunction for quite some time without issue, but I assure you that switch video cards does in fact help signficantly. Although you may find that just replacing the monitor, and selling this one on ebay or craigslist - listing it with the problem you know of but indicating that you have information that shows it should not have the same problem on someone elses computer, and then buying a new monitor would definitely fix the problem permanently. Of course you don't have to do that, but at least you would recoup some of the cost of a new monitor. You can get a new Viewsonic monitor, which is better in all regards for $199 shipped from this link, I've seen it for $400 in some retail stores:
http://www.amazon.com/gp/product/B003Y3BJ7S?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B003Y3BJ7S
And then you wouldn't have to worry about replacing the video card, which would only alleviate the issue, not completely rectify it. Then you'd also have a nice box for shipping your old monitor if you chose to sell it on ebay for example.
Thanks so much, let me know if you have more questions or concerns, just reply here.
Thanks
Tim
Oct 30, 2010 | Westinghouse Computers & Internet
When I boot up my computer, it takes my Acer monitor 20 minutes to show the desktop. It flashes the Acer logo, then goes black, then flashes again, and repeats till it finally comes on. Could it be a...
It's probally the inverter board that drives the backlight in your monitor is failing causing the digital board to reset. I think Acer has a 3 yr warranty. If the monitor is less than 3 years, I would call them and ask them to repair it. They will fix it for free if it less than 3 yrs old, it will only cost to you is shipping it to TX. Hope this helps.
Aug 06, 2010 | Acer AL2416WBSD 24" Monitor
Erratic reading
It still under the warranty, so, in worst case you can send it back for repair at no cost to you. But first try to use this link:
http://www.polar.fi/en/support/downloads?product=&category=User+manuals
This may help to solve the problem yourself.
Rate me, please.
Aug 12, 2009 | Polar F11 Heart Rate Monitor
My monitor stays on for 6 seconds
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 03, 2009 | KDS Radius RAD-7 17" Flat Panel LCD...
Dell monitor p971 driver win vista
(I assume you have this monitor from your old computer as dell doesn't ship it anymore ) P971 is a CRT monitor and comparatively very old dell does not have vista compatible driver for these monitors at all.
Click on the link and you can find the list of the monitors for which dell ships the vista compatible drivers
http://support.dell.com/support/topics/global.aspx/support/product_support/en/monitors?~ck=ln&c=us&cs=19&l=en&lnki=0&s=dhs
Feb 03, 2009 | Computers & Internet
Monitor Samtron after 10min. looses contact with computer
This problem is caused by the Novatek chip on the video board. Soldering a 50 Ohm Resistor across pins 5 and 6 of this chip resolves the problem on both the Samtron and the Samsung monitors. I have just corrected one of these last night by this means.
Hope that helps
Jan 12, 2009 | Samtron Computers & Internet
Monitor looses contact with computer
check the video card if it is properly inserted.
Jan 12, 2009 | SAMTRON 55V 15" CRT Monitor
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
HP Compaq FS7600e CRT Monitor Logo
50 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
