Question about GE Security Simon 3 Wireless Home Security System
I am trying to figure out how to use the remote phone access feature for my GE Simon 3 system. I want to call my panel to arm, disarm or check the status of my system when I'm away from home. ADT keeps telling this feature is not available even though the manual says I should be able to use this feature. Please help, Thanks
  • 80 Answers
ADT has there systems custom made for them. so they may have dumbed down the system so they dont have to spend there time helping with problems.
most system usr the ring hang ring method.
you dial the the number that your system is connected to let ring 1 to 2 timen hang up wait 20 seconds call back the panel should answer then follow your instructions. most panel will have you press somthing like *** them the panel will tell you to enter your access code. then the panel will walk you thru the rest.
mj
Posted on Aug 29, 2009
Simon xt arms itself
there is an auto arm feature programmed in to the system. Check your setting and the system clock.
Dec 30, 2011 | GE Simon XT Wireless Home Security System
Just bought a simon xt system and setting up the touchpad. the touchpad can arm the system but it won't disarm the system when I type in the code?
Note: The default master code is 1-2-3-4 when the security system is shipped from the factory. You should change your code after your system is installed. See Code options on page 26.
If you have already changed the default master code, press the numbers in for the correct code and press enter.
Barring a faulty system the correct code and then 'enter' should sub-disarm or disarm.
Aug 25, 2011 | GE Security Simon 3 Wireless Home Security...
Module ok simon version 3
You need a new battery. 6VDC 1.2AH. The GSM module runs directly off the battery and it is no longer getting a full charge.
AlarmProfessor.net
Dec 30, 2009 | GE Security Simon 3 Wireless Home Security...
When I plug in GE Simon 3 panel it is already armed
Is your Simon 3 new or used? The default Utility Access Code 1 or 2 (i.e. the code you use when you open up the cover) is 654321, 54321, 4321 or 321. The default Master Access Code (i.e. the code you use to arm / disarm without opening the cover) is 123456, 12345, 1234, or 123. The length of the code depends on option 54. Default is 4 digits. If it's a used one that has non-default settings, you can reset memory to factory defaults.
Nov 17, 2009 | GE Security Simon 3 Wireless Home Security...
Motion sensor disarms itself
the system is set up to bypass the motion if a door hasnt been opened during the exit delay. you can either open and close a door everytime you arm the system or if you have access to the installer you can delete option 52 and that will fix your problem
Sep 19, 2009 | GE Security Simon 3 Wireless Home Security...
New house, existing Simon3. How to access to add new sensors
Go to the GE Security website, register and download the installation manual. Heres the link:
https://portal.gesecurity.com/portal/login/login.jsp?TYPE=33554432&REALMOID=06-0008ce40-a18c-1536-85ea-8312f762000e&GUID=&SMAUTHREASON=0&METHOD=GET&SMAGENTNAME=$SM$wqmXYZlDF%2bp9wEfLtfJfgbvvO8xuG0aMyW%2fdUiDGhFTao1t%2b10TkWhV0hWcBh7VC&TARGET=$SM$https%3a%2f%2fportal.gesecurity.com%2fportal%2fmdme%2fDownload.jsp%3fID%3d320%26DID%3d320%26documenttype%3dInstallation$%20Instructions
The master codes are in the manual.
Or google "Simon 3 access code" or "Simon 3 ADT code" or such...
Jun 12, 2009 | GE Security Simon 3 Wireless Home Security...
Problem about remote access by phone or cell phone
You have the right info are you using the master code?
How to gain access to the Control Panel:
1. Call the panel and let the phone ring twice then hang up.
2. Wait at least 10 seconds and call the panel again. You may wait up to 40 seconds
before calling again.
3. The panel should answer on the first ring. You won’t hear any prompt when the
system answers.
4. Press the * button on your telephone and you will hear system activated.
At this point you may perform the actions listed in the following table of phone commands.
CODE refers to the master and access codes programmed into your system.
also contact your installation company to see if this feature is enabled.
mj
Apr 21, 2009 | GE Security Simon 3 Wireless Home Security...
Disarming / Access Code/ Resetting
Ask seller or previous owner the code, or read in the manual how to reset the system to factory defaults
On the previous version (Simon3) it was press cancel + clock set + Minutes+ at the same time and the power up from battery
Jan 05, 2009 | GE Security Simon 3 Wireless Home Security...
We have a simon 3 panel and were wondering if it will auto-arm?
you can get the installation manual here.
http://www.home-technology-store.com/assets/PDF/GE/Simon-Install.pdf
Dec 05, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
389 people viewed this question
Top GE Home Security Experts
Sean
Grantec 2000
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a GE Home Security Expert? Answer questions, earn points and help others
