Question about GE Profile ASM10AA Air Conditioner
I have a sunbeam 12000 btu window unit air conditioner. I can't seem to change the fan speed when it is in cool mode. When I put it on fan only it blows extremely cold air and i can change the fan speed. When i press the power button it stops blowing but it sounds like the motor is still running and I must unplug it to get it to stop.
    Guru:
  • 587 Answers
Sounds like the switch is wired wrong.
When you put the switch on fan only the compressor should not run at all, therefore their shouldn't be any cold air.
Check the switch to see if it's wired right.
Posted on Aug 25, 2009
How do I correct the H3 code problem with the high pressure switch?
If unit shutting off on high pressure that typically means the out door fan is not cooling the compressor
Aug 20, 2016 | Norpole 12000 BTU Window Air Conditioner...
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Why incessant beeping?
    Good Afternoon Friend,
    I understand that your Frigidaire air conditioner, model# FRA124HT2, begins with a constant beeping, and changes the modes itself, about every 30 minutes. I also see that it ends up on a different setting each time it does this. I suggest resetting your air conditioning, by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. Bring power back to it and turn it on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
    May 26, 2014 | Frigidaire FRA124HT2 12000 BTU...
    Why won't my air conditioner change fan speeds
    Having same problem...ac unit seems not to be changing fan speed and cooling level has been reduced ????
    I have no solution. but we have just run into the 7 day of 95+ degrees with high humidity. do not believe the units have frozen up, just seems that the fan is in low speed mode and trying to raise it to F2 or F3 doesn't seem to help.??? Most of the time we have to increase temperature because its too cold ?? now it doesnt seem to be cooling the same ??? I await anyones solution.
    Aug 06, 2012 | Kenmore 75121 Thru-Wall/Window Air...
    Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
    The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
    Aug 06, 2012 | DeLonghi PAC A120E 12000 BTU Portable Air...
    I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
    that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
    So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
    In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
    However, if you try to cool a 800 sq ft room - it will not work as well.
    Hope this has helped.
    Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
    HI there, I have a Goldstar WG1205R 12000 BTU window air conditioner that has no filter, blows slightly cool air and the fan power is very weak for 12000 BTU's How can I improve the performance of...
    Sounds like you have a 220 volt air conditioner plugged into a 120 volt outlet.This will cause the conditions you are describing.
    Put a filter on it please.
    Jul 10, 2011 | Goldstar Heating & Cooling
    How do I get my LG 12000 BTU ac/dehumidifier to dehumidify
    This is a quote from the manufacturer.
    Dry mode is used to remove humidity from the room
    without additional cooling. Once the set temperature
    is reached, the compressor and circulation fan turns
    off and only the exhaust fan will run. Fan speed is
    pre-set and cannot be adjusted.
    Apr 24, 2011 | LG LP1200DXR Portable Air Conditioner
    I RECENTLY INSTALLED 3 LG INVERTER MINI-SPLITS.TWO 12,000'S AND ONE 24000 BTU.THE 12'S SEEM TO WORK GREAT THROWING NEARLY 140' HEAT. THE 24 IS LUCKY TO THROW 90' HEAT AND I DON'T SEEM TO BE ABLE TO CHANGE...
    I think you keep in Auto mode. If in Auto mode, you can't change fan speed. Keep in cool/heat mode and then press fan button in remote to select desired speed.
    Dec 16, 2010 | LG Heating & Cooling
    I just installed a ductless mini split 12000. when I put power to it the outside unit compresser runs no fan the led read out just blinks very fast the remote does't do any thing
    One thing you need to check is Polarity. the 2 wires red and white, need to be on the same terminals inside as they do outside. this is very important.
    Oct 28, 2009 | LG LS-L1210HL 12000 BTU Heat and Cool Mini...
    GE Profile ASM10AA Air Conditioner Logo
    226 people viewed this question
    Top GE Heating & Cooling Experts
    ray gallant
    Lawrence Oravetz
    richie46
    Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
