Fuel pump crankshaft position sensor??? Check for fuel ,spark,air
Check fuel pressure first, if that is ok check for OBD2 engine control system fault codes with a scan tool or code reader.
I can think of 10 things right off the top of my head that could cause that--all require testing. No easy fix here
SOURCE: "2008 nissan rogue problem shifting
It is the battery. It is bad and shorting out. Check the manual for directions to trouble shoot until you replace it. There is a small button that you need to remove next to the shifter, place the key in the hole and hold for about 10 seconds. It is a shift release.
I had the same problem. Fixed!
SOURCE: I hqve a nissan rogue 08 i want to reset the
This works for most vehicles but no guarantee. Disconnect both battery cables from the battery and touch the cables together making sure they are in good contact for at LEAST one full minute, you could just leave the cables off the battery for maybe an hour or so but this process speeds up the draining of any capacitors in your system that hold an electrical charge. After the one minute is up re-connect cables and the light should be out and stay out providing it does not detect faults somewhere which will make it come back on fairly quickly. NOTE: You will have to reset your vehicles clock.
Best wishes!
SOURCE: Location of ac resister on 08 Nissan rogue
This is extensive steps to do this which you will need the actual diagrams from the manufacture. We can give them on our site as we pay them to allow us to distrubute them so there is no copyright issues come by and get the info plus help from a Mechanic
http://www.expertcaradvice.com/askquestion.php
SOURCE: How To Change A 08-11 Nissan Rogue Tail Light Passenger Side
unscrew the cover plate on the inside. it will also be in the owners manual????
Are you sure the battery is good and properly connected to cables? Low voltage connections are very prone to poor connections where the electricity does not have enough pressure to "jump" over obstacles.
Make sure that all battery connections are squeaky clean and tight.
