Question about Refrigerators
Our amana mdl # ARB2257CSR drain is plugged under freezer drawer, need schematic or how to un clog advice
    Champion:
  • 363 Answers
Go to appliancefactoryparts.com
Posted on Jul 30, 2009
Amana freezer door doesn't fully shut
There is a drain inside the freezer part of the arb2257csr. The drain can get clogged and the water from the defrost process will pool up on the bottom of the freezer. You can gain access to the back of the unit and remove the pan drain to clean it out. Then make sure water flows and ice is not blocking the drain. It takes a long time to melt so I used a turkey baster and put hot water into the drain from the lower inside middle of the freezer. This drain pan can get pretty smelly when rancid oils and such don't evaporate the way it was designed to evaporate the water. The symptoms were ice on the inside bottom and water pooling in the front of the drawer. It also became very hard to close the door due to the frozen door slide. I have not seen anyone report this on any site so far. Everyone talks about the thermostat but no one seems to have arteriosclerosis of the drain tube.
Apr 15, 2013 | Amana Refrigerators
Water leaking
If there is water under your crisper drawers your drain line under your freezer panel is clogged up or frozen over.
Jul 28, 2012 | Amana ARB2257CSL Bottom Freezer...
Need a diagram of Amana top freezer refrigerator model #ATB2132ARW My fridge has a clogged drain tube, but I can't locate the drain.
I can't find a diagram but have a different model Amana. The drain tube on mine was located just above the drip pan under the refrigerator. It was a soft plastic/rubber and had become clogged due to something sticky that stuck it together. Caused the freezer water to back up and after cleaning the tube, I had to defrost the refrigerator completely to melt the ice blocking the tube at th top (in the freezer). Sorry I can't help with more info.
Jul 30, 2011 | Amana ATB2132AR Top Freezer Refrigerator
Water collecting under produce bin which has to be collected every couple of days.Amana model # TX21VE 7.74 amps
Your drain is clogged. Every time it defrosts the water from the defrost should drain out to a catch basin under the ice box. That drain is clogged. You need to access the drain and clear it.
AMANA BOTTOM MOUNT SERVICE MANUAL
2 megs printable version
Helpful?
Sep 30, 2010 | Amana Refrigerators
My daughter has an Amana side by side SRD 20S4W. Water/ice puddle on the inside bottom of the freezer section and periodically spill under the door and onto the floor. The problem started about a month...
Yes there is. You will need to remove the back panel to acess it. Try using a turkey baster with warm water or a wire. After clearing mix a 50-50 baking soda water solution and run it down the drain, this will help prevent future clogs.
Jul 27, 2010 | Refrigerators
What is the cost for a repairman to replace the compressor of an Amana ARB2257CSR?
depends on price of parts plus labor time -easy replacement nothing in way to work on unit, wiring good and compressor/freon oil is not contaminated should take about 2 hrs @ $70hr ---$40 house call plus price of compressor[which can be from 100 to 200+] ,freon,filter and other mics parts it adds up quick best is to call and ask for an estimate from a repair service
Jan 13, 2010 | Amana ARB2257CSR Bottom Freezer...
Amana upright freezer leaks water on floor instead of in drip pan under it.
check the flor of the freezer if it is caked with ice your defrost drain is clogged
if not
take off the back panal
under the machine follow the drain tube
to the drain pan clean out your duck bill and make sure the tube is in the pan
Oct 06, 2009 | Amana 16.7 cu. ft. / 473 liter Upright...
I have a model ARB2257CSR Amana frige (freezer on bottom) and the freezer is not working I think. there is a sound that comes on and off like the motor maybe is trying to come on... the sound comes from...
Sounds like the overload/relay is going out . If the noise is a " click " , replace the o/relay after checking the 3 terminals on compressor for continuity and each terminal to ground ( copper tubing ) .
Jul 15, 2009 | Amana ARB2257CSR Bottom Freezer...
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer leaks water!
luvbug, Your refrigerator is "frost free" which means it is automatically defrosts after the compressor runs 8 to 12 hours. The defrost cycle lasts approximately 30 minutes. If it is in normal condition, defrosted water goes through the drain into the drip pan under the refrigerator and then evaporates. The problem you are having is one of the most common - the drain line is clogged up. To fix it you have to remove the freezer drawer, defrost and clean the drain. The drawer removal procedure described in the refrigerator manual book. If you do not have one you can find it there: http://www.amana.com/amana/jsp/manual.do You will see the drain hole on the freezer floor by the rear panel. To defrost it you can use your hair dryer. To make sure it is open, run a cup of very hot water through the drain. Reinstall the freezer drawer and enjoy it! Gendos....post it back
Dec 21, 2006 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
