Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Murray Lawn Tractor Model 42576x92A will not start...no spark?
My Murray Lawn Tractor will not start. I suspect no spark. The ignition switch does not work. When I try to start with it nothing. I can jump accross the seliniod switch and the start will spin. Is it the safety switches? I would like to know how to REMOVE the clutch safety switch, rewire around it to make it run. Currently unemployed so I need a cheap work around. Thanks in advance for the help. The switch has two yellow wires and two orange wires on it.
  • 104 Answers
Http://www.partsandservice.com/bin/ipl.cgi
I found a wiring diagram that I hope helps you out.
Posted on Jul 29, 2009
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Murray model series 760 lawn tractor speed control. Tractor won't move.
Well the lever is obviously not reaching the motor so fix the lever
Feb 18, 2015 | Murray Garden
I nned a wiring diagram for a murray lawn tractor
My search engine, Bing, came up with a great diagram when "Murray lawn tractor solenoid" was put in the images section. It shows clearly which wire goes where on a generic system.
Aug 15, 2014 | Garden
My murray lawn tractor stops running after 10-20 minutes. I replaced the fuel filter and cap, spark plug, oil, gas. I do not have a spark after it cuts off. Any ideas??
First I would bypass all the safety interlocks and see if it still shuts down, if so I would test the ignition switch and if that does not find the problem, the kill wire may be shorting to the block under one of the wire clamps. If all that fails, try replacing the coil.
junkl
Feb 10, 2013 | Murray Garden
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
Model 40601B riding lawn mower-need tension pulley spring
Your owner's manual has a parts breakdown with all parts listed. Find the part # and order from local Sears store. No manual? Try the Murray website (www.Murray.com) and download the manual for model 425001x8D lawn tractor. Good luck!
Sep 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 1993 murray lawn tractor 12.5hp Ignition Switch????
Take an ohm's and amp. meter and go to the ohm's setting and see which terminals are off and on. If you want to kill the engine put it on the off side. If you want to run anything put it on the start and run side of the switch. Hope this clears things up a bit. donnyb60.
Mar 24, 2009 | Garden
No spark on lawn tractor
have you bypassed the ignition switch?? if you by pass that switch and you get spark you know its the switch
Sep 28, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,443 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
