Question about Electronics - Others
How to Repair USB Flash Drives Broken, Unrecognized, Not Detected?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Are the following true for you: your flash drive is NOT actually PHYSICALLY broken, your your computer can recognize it, your computer assigns it a drive letter? If your answer is yes you can always try flash drive recovery software.
However, software will not work for drives that are not being detected, or recognized. This means you likely have a problem with the controller chip on the device, or a physical problem. In other words it has failed, or become corrupt.
Because of the size of the circuitry and parts, how the device receives power, as well as the difficulty of soldering, unexpected damage is a frequent issue with DIY attempts on these drives. Defensorum soldering irons have the potential to burn or melt the printed circuit board, make the recovery much more difficult for a professional, and even cause the drive to be unrecoverable.
Solder can easily be crossed with points on the drive shorting out other components that are required for the drive to communicate with the computer.
Another common mistake is when the prongs, or whatever contraption being used to connect the drive to a computer is improperly connected, the memory chips and/or other components can be damaged due to improper power being supplied.
Posted on Nov 30, 2017
    Top Expert:
  • 8,387 Answers
Hi Jhon.
this is all i could find out.
Navigate Control Panel -> System -> Device Manager -> Disk drivers. 3. Find and select your USB device, right click and first choose "Uninstall" and then choose "Scan for hardware changes" to refresh the drivers. After all the operations, you will find USB not recognized issue is fixed and the flash drive is detected.24 Jun 2016
Repair & Recover USB Flash Drive not Recognized or Detected ...
https://www.easeus.com/resource/usb-flash-drive-not-recognized.html
How can I fix USB device not recognized?Method 4: Reinstall USB controllers.Select Start, then type device manager in the Search box, and then select Device Manager.Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...Once complete, restart your computer. Your USB controllers will automatically install.Error: "USB Device not recognized" when you try to access a USB ...https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces...Search for: How can I fix USB device not recognized?
how to repair usb flash drive not recognized Google Search
3 Suggested Answers
SOURCE: USB Flash Drive (Transcend Jet Flash 1gig) not detected
use device not recognized
Posted on Jul 31, 2008
  • 451 Answers
SOURCE: I want to Save Scanned Data on my USB Flash Drive.
try reformatting the usb flash to FAT and scan again.
Posted on Mar 06, 2011
AWRDACPI usb driver
Can you tell more information about your USB driver? What your problem is? Data problem or unrecognized problem?
Anyway try 4Card Recovery, which can solve all the situations above. How to Recover Photos Videos off SD Card after Formatting Unformat SD...
Mar 20, 2014 | Kingston Electronics - Others
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Every tym i insert my pendrive it says insert disk into the drive...???removable disk appears..but it doesnt opns...is there any solution...plz do help me
Assumption 1
Flash drive is damaged, the normal operating system.
Solution
If the flash drive is detected (eg; detected the flash drive in drive G), but it says "insert the disk into the drive ..."
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download).
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
If the flash drive is not detected (not detected as drive G),
the above solution can not be used.
Assumption 2
Normal flash drive, the operating sytem is corrupt
Solution
Flash drives do not require drivers (plug and play). Because flash drives plug and play, it should be, when the flash drive inserted detects the operating system without installing drivers. But, if the operating system does not detect, the possibility of operating systems corupt. The cause is a virus corrupt your operating system.
1. Download and install anti-virus Avira or AVG (free).
2. Update anti-virus
3. Scan your computer.
4. Repair the operating system.
5. If no virus is detected, the possibility of operating system is corrupt.
Oct 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Unrecognized
some proble was in USB socket of your external HDD...poor contact...
try to use another HDD enclosure to use with you HDD..
that problem occur due to pluging in and out several times...maybe the connector was damaged...hope it helps..
or try another PC again...some problems are not detected due to virus in PC...
May 25, 2010 | Western Digital Passport WDXML800UE...
How to repair a malfunctioned pendrive
If the pendrive can still be detected, all you could do is format it.. if it can't be detected..then option is to purchase a new unit..
May 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Flash drive
Hi phun2008
Did your question get answered? (I'm not sure what "no thanks" was in response to.)
Your flash drives should work fine w/ Windows XP. They should be detected by the operating system as mass storage devices - plug-n-play - w/ no need for drivers installtion, etc.
You may, however, experience detection issues w/ them on systems w/ older USB hardware. If the flash drives are USB 2.0 drives, they will not be detected on systems running USB 1.1 or earlier - regardless of the OS (operating system) installed.
On the other hand, if they are USB 1.1 flash drives, they should be detected fine on both older and newer USB ports as USB 2.0 is "backward compatible".
I hope this helps.
BJ
Apr 03, 2008 | Computers & Internet
Electronics - Others Logo
74 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
