Microwave Ovens Logo
Luzetta Russo Posted on Nov 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic microwave keeps blowing fuses jus put in a new fuse but after a few days blowes another fuse
zappal
Level 2:
Sergeant:
  • Expert 256 Answers
  • Posted on Dec 01, 2017
zappal
Expert
Level 2:
Sergeant:
Answers
256
Questions
0
Helped
65260
Points
750
Luzetta
This is a common problem with microwave ovens and is easy to diagnose. Whenever I replace the fuse, I always perform this test. I don't want the unit coming back in a couple of days with the same problem.
Install a known good fuse. It should be a 20 Amp, Slo-Blo, with a ceramic body. Leave the cover off. Place a container with at least 2 cups of water inside the unit. Cook on high for at least 5 minutes. As soon as it finishes, UNPLUG the unit and feel the fuse. If it is extremely hot, the fuse is going to fail in a short period of time. The fusible material inside the fuse is melting from this excessive heat. It only takes a small amount of resistance at the fuse holder contacts to create this amount of heat. Replace the fuse holder rated at least 20 Amps. The higher the better.
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Nov 19, 2007
SOURCE: Microwave keeps blowing fuse
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
If it blows the fuse as soon as it's plugged in, you probably have a shorted door switch, a shorted varistor, or an internally exposed wire shorting to the chassis, etc.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 13, 2008
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links with info on part testing:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
  • 11 Answers
  • Posted on Jun 02, 2009
SOURCE: microwave blowing fuses
Sanyo isn't that great of a manufacturer.. I had a microwave from them a few years back that did the same thing.. The wiring inside the microwave is shot.. if you were to open it up, you'd probably see some burnt wires from a short. If you use the microwave over a range, it may be because of grease build-up...
anyhow, its better that you invest in a new microwave, rather than fix it. It will be much more cost efficient
Anonymous
  • 1922 Answers
  • Posted on Jul 27, 2009
SOURCE: My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
Anonymous
  • 612 Answers
  • Posted on Aug 28, 2009
SOURCE: Ewave over the stove microwave fuse blows when I
The light is the only thing that comes on when you open door. You either have a shorted door switch (Micro switch) or a shorted bulb. You have either a shorted bulb or bad socket. From my experience, it's the bulb. Just because it may seem to start to come on when you open the door, it's most likely bad. At least it not expensive.
Please rate solution
Testimonial: "Thanks, yes the light comes on for a second then fuse blows. I'll replace it, thanks!"
Panasonic inverter microwave ct579 killing the 10a fuse. Uk.
Check its transformer so that you will know its fuse size
Fuse keeps blowing Found out we shouldn't have it
A 20 will work but I would change it to the correct on as soon as possible...
heatman101
Fuse in microwave oven keeps blowing
does the fuse in the plug blow or the internal fuse if it blows the internal fuse it could be one of the door switches two of the switches have a red button on them and one has an orange button its normally the orange one thats at fault
2helpful
Microwave blowing fuses
Kenmore Micro/Oven fuse keeps blowing
Disconnect the connector to the primary winding of the high voltage transformer. Put a new fuse . If the fuse is not blowing the problem may be in the secondary side of the high voltage transformer. Chek the highvoltage diode, capacitor, magnetron respectively. you can also check the primary winding of the low voltage transformer.
Sanyo EMS1000 microwave. Keeps blowing 13amp plug fuse.
New or older wiring to microwave? Is there a GFI circuit installed?
Blowing Fuses
never put higher fuse then what is already there can cause a fire microwave are being made more disposable now either use warranty or buy a new one i am lucky if i get one to last a year before it starts acting up cheaper to buy new one then to have it repaired
The fuse blows when i plug the microwave in with the door closed
first you gotta detach the button plate ( the thing with all the buttons) using a flathead screwdriver .Keep pushing it is stuburn. It will pop back in when you are done. the fuse is behind that. just take it out and put the new one in.
3helpful
4answers
Fuses keep blowing out
In case it's still helpful, I'll inject a little sanity into the replies.
If the fuse blows as soon as you hit Start, it's probably a shorted high-voltage capacitor. That's usually economical to repair.
If the fuse blows a few seconds after you hit Start, it's probably a shorting high-voltage transformer. That's usually not economical to repair.
It's not radiation (non-ionizing RF by the way) that's the hazard, it's the voltages.
Top Panasonic Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
