Question about Garden
Edger - shaft broken
I have a Ryobi edger 725r rev 800 and the shaft broke off at the clutch. Is this worth taking for repair or just buy a new one?
  • 130 Answers
Take to shop and ask them how much would
it cost to fix and then you can decide from there.my guess is buy a new one.have to look at it first to be 100 0/0
Posted on Jul 30, 2009
How to remove bell houseing from.ryobi 725r
You must remove the boom, clutch housing, and the clutch assembly. Clutch drum will have most likely a trox head retaining screw accessed through drive cable hole.
Oct 21, 2014 | Garden
How do you fix the trimmer shaft if it won't spin?
simple answer is no if you can do it yourself then yes
Aug 15, 2014 | Troy Bilt Tb70ss Gas Trimmer
Broken flexible shaft
There are so many details missing from your question...
first, does the shaft break down into 2 pieces ( so as to accept different attatchements) ?
if so which end is broke?
second, how did you determine the shaft is broke?
have you eliminated the possibility of a stripped end in the head?
Have you eliminated the possibility of a stripped end in the clutch ( the most likely cause of failure) ?
Have you eliminated a failed clutch?
I suggest you diagnose the unit carefully first then decide what it is worth to you to fix versus replacement. A shaft is about $30 from your local dealer.
Nov 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
725r trimmer
You can buy new Line to re-spool on your existing head
Aug 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I broke the flex drive shaft but can't remove the head to get out the broken shaft piece. I got the big part of the shaft out from the top. the bump head has been replaced by the kind that you cut 2 pieces...
The flex shaft drive you are referring to is only sold as a assy that I am aware of. You can try www.partstree.com for the replacement shaft assy. you are refering to, however you may find out by the time you buy a new shaft assy you may be money ahead just buying a new trimmer.
Sorry
Aug 08, 2009 | Ryobi Garden
My Ryobi weed eater Model 725R Rev B00 both feed and vent hoses are rotten one broke off the fuel tank and appears to have been fastened to the the tank by glue or (???) Can I purchase a new tank with...
I fixed mine with hose from a auto parts store. It was air line for a air ride shock. I removed the tank and fed the new hose thru the tank with wire. Heat it at the end to push over the nip on the carb. Back to work now, cut that grass.
Jul 24, 2009 | Garden
Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
May 25, 2009 | Ryobi Garden
The pull rope broke on my ryobi 705r/725r gas trimmer. I have all the screws off but it seems to be held on by the center shaft that spins. What do I do now?
I have the same issue of clutch removal on a Ryobi 725r. Actually the clutch finally died after many years of use.
Instead of using a screwdriver to hold the piston I recommend using a piece of clothesline rope. It will be easier on the internal components and won't scratch up the cylinder walls or piston. Just be sure to leave a small amount hanging out of the spark plug hole so you can pull it out afterward.
Apr 15, 2009 | Garden
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
