Question about Watches
Needing a manual for a Rawlings golfers(?) watch, serial # V-888
I have had no luck in locating my manual that came with it, any ideas as to how I can find another manual for it so I can set the time and stuff?? Its the kind you clip on ya belt, if that helps........
  • 302 Answers
SOURCE: manual for rawlings 78001 watch
press and hold mode, a digit should flashpress another button and change the digitpress mode again, different digit should flash, change it, repeat until complete
Posted on Oct 14, 2012
0 characters
1 Points
William moulton pocket watch serial # 7518892
With just a serial no way to tell you the worth of you watch. Is is ordinary metal, silver, goldplated, gold...
Do you have idea if it's new, vintage, antique..
Give some more description please so someone might help you
Apr 25, 2015 | Pocket Watch Watches
Manual for rawlings 78001 watch
Oct 14, 2012 | Invicta Watches
Rawlings model 75003. no manual. I cannot adjust time and date
keep pressing mode until you see the seconds blink then press reset to go to hours and change the time with the start button and reset again to change the minutes and same as before start to change
Mar 31, 2011 | Watches
Help me set the time et al for a Nokia chrono alarm timer watch attached to compass and caribiner. Made in China.
I don't have one of these, but I ran across a web blog that explains how to set the time and alarm for hopefully a similar Nokia, and here's the page:
Good luck, and hope this helps.
Nov 28, 2010 | Watches
I want to buy a replacement watch strap for the Puma Drive Chronograph Watch PU111F20118032
On most watches, you can only get replacement bands that fit the style of watch through the original vendor. You will have to contact Puma and be ready with the case #s on the back of the watch. Good luck.
email: or call 888-565-PUMA
Jul 19, 2010 | Puma Drive Chronograph Watch...
Where can I get a manual on the use of the Robotic 888 Stop Watch
Try: Maybe they have got one on there! Tarr, Phill☺
Oct 14, 2009 | Bulova Watch
Casio watch problem
Appreciate the direct "Ask Me".
Offhand, I would say yes to the battery replacement. Though watches are not within my immediate field. This would be based on your post "2-5 minutes behind". As to the "lost signal" after a reset, may I request that you post back the specific model number pls.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Watches
Aspen watch
Setting my Aspen Digital Watch
Button designations:
To Set Time, Date and Day:
Press A 3 times; Seconds Flash; Set to 00 with C
Press D; Minute Flashes; Set Minutes with C
Press D; Hour Flashes; Set Hours with C
Press D; Date Flashes; Set Date with C
Press D; Month Flashes; Set Month with C
Press D; Day Flashes; Set Day with C
Press A to Quit
To Set Alarm Time:
Press A 2 times; Hour Flashes; Set Hour with C
Press D; Minutes Flash; Set Minute with C
Press A to Quit
To Set Alarm ON or OFF:
Hold D in to see Alarm Time and Press C to toggle Alarm ON/OFF
Hold C to see Month and Day.
Hold D to see Alarm Time; Press C to toggle Alarm ON/OFF.
Mar 27, 2008 | JCPenney Armitron Sport Link Bracelet...
Leather Band
Do you need the same strap that was on it? The only way to try to get that is through Kennth Cole, and they probibly will tell you it is discontinued, but try. If you are not needing the exact band , take your watch to a watch repair shop, they will have bands that will fit your watch and probibly the style too. If you find you can't get what you want ,PLEASE let me know and I will do my best to find what you are looking for. Good Luck!
Feb 18, 2008 | Kenneth Cole 1213 Wrist Watch
Its actually for a Cartier W10172T2 Circa 2006
I have the same problem and would be interested if you have received any answers to this problem?
Aug 22, 2007 | Cartier 21 Chronoscaph W10125U2 Wrist...
Watches Logo
70 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
