Question about Pioneer DEH-P690UB CD Player
I have a pioneer car stereo after a battery switch my amp gets power, but my subwoofers don't work
  • 85 Answers
Is the light on the amplifier on. is your remote wire the blue wire with power. if not you have a remote problem but if it all works check your rca's on the radio or your amplifier.
Posted on Sep 08, 2009
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
Trying to install a Alpine 3552 amp, can't get power, not sure how remote switch works?
make sure you have a good ground. use a continuity tester. local retail or stereo shop sells one for about $10-$20. make sure you have power (fuse should be within 12" of battery). the remote wire off the stereo (usually blue) can be your remote switch. this has to be connected for the amp to work and stereo must be turned on.
Jul 23, 2011 | Alpine Car Audio & Video
Can I connect two Sub-woofer speaker to my car CD receiver Model No.DEH-P4950MP without using Power Amp ? because I really don't need very high Audio sound volume but I need to hear all Audio...
head units do not provide enough power to run subwoofers. instead, get yourself some new door speakers, and enjoy the difference. if not, you will need an amp to power the subs.
May 05, 2011 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Ok i just got the sub from a sony sswg450 i want to know is there some way to hook it up to my Pioneer home Receiver
Did you get a manual with it? According to the Sony site this speaker originates in Sony MHC-GX450.
"This product bundle includes the following models:
HCD-GX450 - STEREO MINI SYSTEM
RM-SC3 - REMOTE CONTROL for Shelf Mini Systems
SSRG444 - FRONT SPEAKER FOR MHCGX450
SS-WG450 - SUBWOOFER FOR MHCGX450"
Find the manual here and learn a bit about your seprated sub...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX450
See page 7.
As can be seen, the subwoofer has two connections to the mothership, very unlike the standard speaker level (+/-) speaker wire or RCA-Line-Level subwoofer out that 'normal passive or active subwoofers use, respectively.
Not knowing which of those your unspecified Pioneer receiver supports, it is impossible to say. Does your Pioneer have that control jack?
Mini-systems are generally not designed to be pieced out and used with grown-up gear. The absence of standardized connections is the clue.
Apr 17, 2011 | Sony MHC-GX450 CD Shelf System
Wireing diagram for a 03 gmc sierra pickup for a pioneer DEH-1200MP stereo please
Hello my name is Israel and I will help you. The following information will help you out. Please rate. Good Luck.
Feb 28, 2011 | Pioneer Car Audio & Video
My jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Feb 08, 2010 | Jamo SUB 200 Subwoofer
Cant get amp and sub to work with the pioneer avic n3
Should be plug n play. Sub out on the unit to the amp and remote turn on from the unit to the amp. If it's not turning on, check the amps remote fuse. Did you replace the previous unit or was it stolen? if stolen, your amp could have been shorted. Just a guess.. If you've got a meter, check the voltage at the amp with the radio "on" at the trigger, should be between 12.2 and 13.8. Also, check the main power for the amp, it runs to the vehicle battery and should be fused as well at the battery and at the amp. Then check your ground, it should be to the floor, not a seat bolt or rear/side/ wall, the factory welds inhibit the amp from grounding correctly, even if it worked before, the amp will run much cooler and more efficiently if grounded to the floor. Just look underneath before drilling a hole! fuel lines and electrical harnesses run in the channels, just be careful. If you still have a problem, post a comment and I can help you some more.
Jun 23, 2009 | Pioneer AVIC-N2 Car DVD Player
There is no sound coming from my 15's when my stereo is on
it is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
Feb 03, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
My car stereo shuts off when i adjust the volume of my amplified subwoofer
your power suplly is either not good meaning the power cable is too small or you don not have enough ground. try adding a bigger cable for ground and power (dc).
Aug 12, 2008 | Pioneer MONO CAR AMP 1000W X 1 Car Audio...
Pioneer DEH-P690UB CD Player Logo
77 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
