Shows error message E3 40 but works sometimes and not others. Someone said a sensor could be dirty, but how to fix the problem is our question.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
This is a canon generic problem of fixing unit.If it is a repetitive check your AC supply ,if it is not stable try to connect a 1.5kw AVR or check the electric outlet maybe the conection is loose ,hope this will help
Posted on Jul 30, 2009
Have an audi a4 quattro 2005 convertible problem is 3rd brake light will stop working and than work again. i also get dash warning when it goes out. will replacing brake switch fix this. also 2nd issue...
The brake light issue isn't likely the the brake switch (since it sounds like your other brake lights are working properly). It's likely a bulb in the third brake light. When the filaments get old they sometimes lose and regain contact as the car vibrates on the road. Change the bilbs and see if the problem goes away. If it doesn't, look for a bad wire connection around the third brake light. Also, have someone verify the third brake light isn't working from the back of the car when you see the alert, it could be a bad sensor.
Jan 05, 2013 | 2001 Audi A4
What does the error message "out bin full" means
This error indicates that the sensor that detects when too much paper is stacked in the output bin to allow more paper to exit. This flag sometimes sticks and a quick check is to make sure that nothing has become jammed where the paper exits the printer. Most common cause is the flag getting jammed because someone has remove the paper the wrong way. I have never seen the actual sensor fail.
Jul 06, 2011 | HP LaserJet 8000n Printer
Hi There. I have Tally T2265 Serial Matrix Printer. It shows "Hardware Alarm & Check Ribbon Error" after printing 2 or 3 pages. Sometime it prints 7-8 pages and sometime it prints 2-3lines...
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Before suspecting other components check the printer model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribbon should be 062471.
If the correct ribbon is used the problem could be the timing strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be caused by the timing station on the carriage, the carriage motor.
Mar 10, 2011 | TallyGenicom 2280 Matrix Printer
Message center keeps showing service tire pressure system soon . what is the problem .
The sensors of the tire pressure are located inside of each rim or wheel, sometimes get dirty sending error messages like this or low pressure in one tire
Dec 28, 2010 | 2003 Chrysler Town & Country
Clp-510 constantly gives paper jam error, although none exists.
false error message / could be due to the dirty rollers or bac=d sensors on the printer. Sometime when printer does not get enough power it might give this erropr message .
Hence also try to change the power source.
Oct 16, 2010 | Samsung CLP-510 Laser Printer
Paper jam problem fixed after removing toner and removing paper, but also now getting auto showing as well and ready and the cartridge ink levels. Auto not their before and now not printing. No errors...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever. Check the following video hope this helps you.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Aug 26, 2010 | HP LaserJet 2840 Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Scanner 5 Error Printer in shop but unable to get new parts
The solutions for this are posted elsewhere on this site, look for "Scanner Error 5". Basically, it's one of several things that can be cleaned or adjusted without having to replace the entire scanner head. If it does need parts they should return the printer to you until the parts are available. This error does not prevent you from printing. Even though the printer shows the error message and tells you to cycle the power, you don't need to. It will still print with this error. Find a repair shop with someone who knows what they are doing, or get a #10 Torx screw driver and fix it yourself.
Read the other thread. Could be dirty mirrors, dirty or crooked film sensor strip, or bad light bulb, all of which can be easily repaired.
Jul 23, 2009 | HP LaserJet 2840 All-In-One Printer
Minolta CS PRO black/white copier has error code
COF30 THIS CODE SHOWS THAT THERE IS PROBLEM IN AUTO TONER SENSOR.MAY BE IT IS DIRTY .CLEAN IT PROPERLY .OR REPLACE IT.PROBLEM WILL BI REMOVED.DO NOT FORGET TO RATE A SOLUTION.MIAN JEE
Feb 12, 2009 | Minolta EP1083 CS/PRO Copier
Ricoh GX3000
ERR (990) or ERR (999) are both error messages which are displayed when a sensor does not work normally due to dirtiness. For example, either may be caused by a dirty maintenance unit or clogged ink nozzles. It may be possible to resolve the issue by cleaning the device
look here for instructions:
http://www.ricoh-usa.com/support/knowledgebase.asp?tsn=Ricoh-USA
Jan 25, 2008 | Ricoh Aficio GX3000 All-In-One Printer
57 people viewed this question
k24674
jasbo
jasbo
