Question about Rival Premiere Dual Travel Mug Coffee Maker
Does the Rival Premiere Dual Travel Mug Coffee Maker use regular coffee or pods?
  • 162 Answers
You can get number 4 filters for regular coffee
or use pods
Posted on Jul 29, 2009
Cannot get past prime funtion
Dirty tubes, manually clean,
Nov 17, 2013 | Keurig B60 Coffee Maker
Rival Coffee Maker #PIL HC10106 Instructions how to program coffee maker
lost measuring spoon for pil-hc10106 what is the equivalent amount?
Apr 02, 2011 | Rival Programmable 12-Cup Coffee Maker
The water or coffee does not come out correctly anymore. When making a cup of coffee (w/ pod) or just hot water (no pod), the hot liquid does not come out in a steady stream, it goes everywhere. When i...
211333Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Keurig Elite B40 Coffee Maker
My brewer has 3 settings for dispensing coffee. Coffee cup, mug, large mug. It doesn't fill a mug or a large mug. It only goes half-way. Any suggestions how to remedy this problem?
Your problem is on the setting section of the coffee maker. Try to check if there is a visible adjuster knob or variable resistor to adjust the setting for the mug and the large mug. If there is none the adjustment is to be done by opening the system panel of your coffee maker.
Nov 02, 2010 | Keurig Coffee Makers & Espresso Machines
I am interested in purchasing this 6 cup brew station, but all pics I see use travel mugs. Can it be used with regular 10 -12 oz ceramic mugs for home use? How about 6 oz cups that match Corelle...
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
Feb 20, 2010 | Hamilton Beach 48274 BrewStation 6-Cup...
Philips senseo coffee is watery
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
Dec 27, 2009 | Philips Senseo HD-7810 Coffee Maker
Tassimo - Can other pods be used?
I am not sure if you have a TARGET store near you, but I found some different Tassimo products there this past weekend.
Feb 01, 2008 | Braun Tassimo Espresso Machine/Coffee...
Senseo coffee problem
The pod holder has an O ring to seal the black plastic disc in,if it is not sealed you will end up with more volume and a weaker coffee without the foam,either knock the disc out and try and seat the O ring and then knock it back in or buy a new pod holder,I had this same problem
Nov 30, 2007 | Philips Senseo HD-7810 Coffee Maker
Coffee Makers & Espresso Machines Logo
149 people viewed this question
Top Rival Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Rival Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
