Question about HP Officejet 5610 All-In-One InkJet Printer
After paper jamming in printer paper now wrinkles
After paper jamming in printer several times, paper now wrinkles while trying to print page and I get a popup message that says I am out of paper when I am not
  • 11,896 Answers
There still may be a piece stuck somewhere in the unit. Remove printer cover and check inside to see if there is anything at all still in there
Posted on Jul 29, 2009
  • HP Master
  • 4,338 Answers
Look inside at the rollers. There is probably pieces of paper stuck on the side where the paper is wrinkling. Remove the paper, the clean the rollers with a cloth and some alcohol.
How do I attack the HP psc 950 paper jam of several sheets, powered it off but I cannot open the rear door.
Do try to forcefully open the door as it may damage the printer. Try to pull papaer if you can see. In case still not possible, take help of a professional.
Jan 25, 2012 | Office Equipment & Supplies
Every page printed has a wrinkle pressed into the paper
Its or moisture issue or wrong pressure between fixing roller and press roller.
Jun 30, 2010 | Office Equipment & Supplies
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
When printing, the sheet of paper always gets jammed.
check the wheels that pull the paper through. sounds like only 1 is grabbing. see if it fell off track
Jul 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
HP Photosmart C6280 paper jam--won't print (of course), message reads 'add paper to main tray'
Please try this to clear the paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | HP Photosmart C6280 Printer
Left corner of paper wrinkles when printing
I know several reasons, and they are all related to an obstruction of some sort..whether it be a small piece of paper along the paper path, to something slightly bent, or broken...impossible to say for sure
Feb 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Paper jam notification after printing one page, no paper jam
try this
alternative :
Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Paper Jam
try this
alternative :
Sep 21, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
360 people viewed this question
Seeker5211
Seeker5211
