Question about LG CHOCOLATE VX8500 Cellular Phone
Word cant figure out how to change the word in the word mode for texting like say i type he itl come out as hi and i dont know how to scroll through words
Click on the zero button i think......and then wen u do it will change it to different list of word u coulda typed
Posted on Nov 27, 2007
I cant get the programme up and down to work and wonder if its in txt mode but i dont know how to change to dtv mode
the two are usually not related---text is a mode for either captions or a black box on the screen and I presume you mean dtv not tvt.
Aug 27, 2012 | Alba LDVD1538WDCH LCD TV
How to change font size on text messages for samsung comeback
go to a text. then press the side arrows next to the charger slot is
Nov 19, 2011 | Samsung Comeback Cell Phone
Cant change language to english go to system configeration but dont have english and dont know what languages are coming up.
To change the language settings on a Playstation 2 console, proceed as follows:
1. If there is a game disc in the console, remove it and then power the unit on/off.
2. When the opening screen appears, choose the bottom option of the two. You will see the foreign text, then the time and date beneath it.
NOTE: If you do not see the date, scroll through the options until the date appears.
3. Press UP once to get to the language select option.
4. Press X to select this option, and then select the choice to the right (English) by pressing X.
5. All the text should change to English.
6. Return to the Time and Date Setup and verify or set your time zone.
7. Press CIRCLE to exit the configuration menu.
8. Insert the game disc and navigate to the Browser menu to select the game or browse the memory card.
NOTE: If the PS2 is currently in another language, then you need to figure out which language it is in so that you can look up the translation for ENGLISH. Once you have that figured out, it should be a matter of changing it back and calling it a day.
May 27, 2011 | Sony PlayStation 2 (PS2) Console
Change to single letters
when you open to send text go to menu thern go to entry mode then select secondary mode..
Sep 27, 2009 | Motorola Mobility RAZR V3
Just got a Samsung g600, Under settingd I dont have 'sound settings' as with previous samsung fone. This means that I cannot assign a ring tone for text messages I cant find any way to do this. I also...
Hi, for anyone still having this problem with the newer Samsung phones, I just solved the issue I posted up earlier.
To disable keypad tones, but keep your ringtone etc active, go to Profiles -> edit your 'Normal' profile.
Press right on the selection pad twice to get to phone-related settings. Scroll down to the bottom of that page of settings to the 'Phone sound volume' option, select it and adjust it to zero.
This will turn off all keypad noises and other irritating beeps while not actually turning your phone on to 'silent mode', which would disable your ringtone etc.
Hope this helps, I know I was going insane with this phone until I figured out how to turn those sounds off.
Jul 23, 2008 | Samsung Cell Phones
Get no connection useing 6100 modem connected to wireless B router
Hi starman re westell 6100.
Hi i hope you have find solution with your issue ifnot let me walk you through on how to get it up and working.
First , you need to connect your modem directly to your computer. We need to access its Graphic Unit Interface by opening your browser and type onyour address bar its default gateway.
The def. gateway can be or depending what ISP youre connected to . For ATT broadband its / verizon broadband is  { onyour address bar : type in and hit Enter.
to check def gateway : you can go to start > run > cmd then enter > on DOS command type in ipconfig /all  then HIT enter > itl provide you your network list > your default gateway is your westell modem or if your linksys is connected than it should be you linksys.
Itl route you to your westell page. Try to go to  Broadband and choose connection or configure connection.button. Look for configure and by default you will see its in PPPoE> change it to bridged ethernet and save.
By enabling bridge to your modem w/c is westell youl have a chance to configure you linksys to PPPoE.
Connect you westell to your linksys and on your computer try to check your default gateway as seen above. By default linksys can be access by typing in or Itl prompt you for UN and PW: by default your Username is : Blank and Password should be admin. { blank = dont type anything}
On your linksys SETUP page > by default it is set to DHCP or obtain IP address automatically. Pls change it to PPPoE and type in your UN and PW : username@isp { your ISP name}. and hit save settings or save.
Restart your linksys and try to browse to check fore connection.
For all types of modem such as westell : you need to set it to bridge mode first foryou wireless router to work ie linksys. Set linksys to PPPoE .. that should work .
For more detailed steps or questions re: this issue pls dont hestiate contact me. Best wishes.
Pls enable you Wireless Encryption for your home network security.
Ciao .
May 21, 2008 | Westell Wirespeed LiteLine 6100...
Can't get the all caps off when texting
I had the same problem on my Motorola C139 TRACFONE, and I just figured it out. When you type a letter, quickly hit the "0+↑" button. If you don't do if fast enough it will register as a +. But if you do it quickly it will change the case of the letter typed. To put it back just type the next letter and quickly hit the "0+↑" button again and it will change it back. hope this helps TW
Feb 26, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Automatic signature?
the RAZRs wont add a signature, even if u put one in. i have the same problem on mine.  Ill c wat I can do, but idk if i can get it 2 work.  A nice fone 2 get wud b a samsung,  THANKS 4 RATING
Feb 09, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Duplicated text in illustrator 10
This is very useful to me as an IT, try, its secure and reliable it is a file conversion online. you dont need to download anything cost $7/mo only all types of conversion. But if you decide not to buy it is ok still cause its FREE, Try it, I had same problem, I used this instead. Please dont forget to rate me. Thanks
Jan 25, 2008 | Computers & Internet
LG CHOCOLATE VX8500 Cellular Phone Logo
48 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
