Question about Kenmore Refrigerators
Kenmore refrigerator # 106.57032602. Ice maker uses the Emitter - receiver system to control ice level. The emitter sends a beam thru cutouts in the ice bin, and when receiver cannot see the beam, stops ice production. Stopped making ice, and red light on freezer liner just blinks now. Unit is 1+ years old, and out of warranty. How can I determine which part is defective, the emitter or the receiver PC board? Is there a way to check that the emitter is putting out the ice level beam? Thanks for any help.
  • 1073 Answers
SOURCE: Whirlpool Icemaker Swith has ** light
the kit number is 4389102 it has both the emitter and reciever as one part, change both in the kit
Posted on Apr 11, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: Kenmore side by side refrigerator model 106.5702 will not make ice.
your ref board seems to be working fine
Did you test the water valve???
if yes and water valve works, than replace the Ice Maker
Posted on May 11, 2008
SOURCE: I have a Kenmore 106-53642300
Could water be frozen -try heat gun not too much heat
Posted on Jan 31, 2009
  • 11 Answers
SOURCE: Whirlpool Side By Side not making Ice, but water dispenser works
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Posted on Mar 16, 2009
Ice full light continues to be on, will not make ice
Make sure the small emitter that sends a beam through the ice bucket to read ice height is not blocked or dirty...
Apr 21, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
The icemaker in my whirlpool side by side freezer is not working it seems there is no ice or water in the maker and the motor is not turning
If your ice maker is the type that sits sideways near the front of the door and you have a beam that senses when door is open the emitter and receiver have gone bad and must be replaced along with the ice maker control module located behind the front cover of the ice maker. The emitter receiver runs approx. 120.00 and the module about 80.00. Hope this helps.
Feb 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Keeps making ice, i can't seem to make it stop.
You have an emitter and receiver in the freezer section...Actually when you slide the lever on the right side in the middle of the freezer section, you break the beam...and it is suppose to stop the ice maker from harvesting ice anymore. If this shut off device fails, it can fail in the on position and continue to make ice. Replace this assemlby sold in a kit and you will be fine. In the mean time, if you can remove the ice maker head and unplug it, that will stop the ice until you can replace the emitter and receiver assembly. You can also shut the water off but the ice maker will continue to operate, just not dispense ice. If extending and waiting on this repair you should disconnect the ice maker.....
Mar 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not making ice
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Jan 04, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice maker is not making ice.
Dec 27, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Make sure that the filter is the right one and that it is pushed in all the way. The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Kitchenaid # KSRA25C
Some precautions before diagnosing the icemaker optics system since there are two different sets of emitter-receiver optics boards and therefore two entirely different procedures for emitter-receiver optics board diagnosis. This could get really tricky especially when the appropriate tech sheet isn’t handily available. To determine which optics diagnostic procedure should be employed, open the freezer door and observe the right side (mullion or partition side) LED status light. If the red LED is NOT flashing two repeating pulses, this usually indicates the older style emitter-receiver optics boards are used and its specific diagnosis procedure should be employed. But then again, this could also mean that the new optics system IS used but the icemaker just happens to be in the harvest mode - OR - the LED (optics receiver) has failed in some bizarre twist of fate. However, keeping the above cautions in mind, we can assume that normally the older emitter-receiver optics system will NOT have its red LED status light flashing each time the freezer door is opened, while the NEW style optics WILL have its red LED status light double pulsing at each door opening.
Aug 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not making ice.
the infa red sensor should be on constant if the switch on the right is in the on position, if the ben is enpty
if the ben is full the beam will flash interpting the ice maker from making ice untill the level of ice drops down below the holes in the bin then it will make ice again
beam part number if needed is4389102 it comes as a kit with the emitter and reciever boards
Dec 28, 2007 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
104 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
