Solution #1
posted on Feb 05, 2008
You didn't state your model number, they have different ones. Take off the bottom plate, the belt and brushroll will be exposed. If you canned see the motor shaft to put the belt on, then the top cover will have to removed also. Usually is a couple of screws from the bottom to take out, then you wil see a slot on each side from the bottom, use a flat blade screwdriver, put intoi slot and pry up to release locking tabs, top will come off. Belt goes from brush roll to motor shaft. If this is the model that uses 2 belts, then the belt goes from the motor shaft to the bigger pulley, and the Vee belt goes from the smalled pulley to the brush roll.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE 106766 Bagged Canister Vacuum
Black & Decker 15.6 Volt DustBuster Vacuum
Black & Decker CK1300 Dustbuster Wet/Dry Vacuum
Bosch BSG71310UC Bagged Canister Vacuum
Black & Decker CHV1400 Bagless Handheld Cyclonic Vacuum
Black & Decker CHV1500 Bagless Handheld Cyclonic Vacuum
Bosch BSG81360UC Premium Health Guard Bagged Canister Vacuum
Can you Help with these Vacuums problems?
Hoover Windtunnel Supreme U5280-900 Upright...
hoover wash m/c agitator...
I need to remove the agitator... Answer This...
Filter Queen Majestic Canister Vacuum
stopped working
stopped working
My filter queen just stopped... Answer This...
Repair Service
Find Vacuum Repairman Near You:
