Question about Samsung Computers & Internet
One side of the screen is flickering badly. - Samsung Computers & Internet
  • 748 Answers
Hello
Either there are capacitors in the power supply failing or a chip is failing. Iany case you'll need to take it to a local service person or send it to a company like mine.
Posted on Jul 30, 2009
Picture with distorted,flickering, darkened area on rt. side of screen . Up to half of the screen sometimes. Sometimes looks like vertical hold is rolling some. Then will be clear with no or tiny amount...
There are several possibilities here.
To be able to help better we'd need to know the model number.
The most likely suspects are the T-CON board, one of the two backlight inverters and the display itself.
Of those only the last one is usually not curable.
Here's an example of a popular set of inverters that , when one goes bad you can get one half of the screen very dark:
http://www.coppelltvrepair.com/p/428/sanyo-dp42848-p42848-00-backlight-inverters-replacement-for-dark-screen-no-image-problem
On the other hand, if you have vertical shadows and some flickering that's probably NOT going to be a backlight inverter.
Flickering would be caused by either the T-CON or the panel.
Since a bad panel is mostly NOT curable you may want to check the price of a replacement T-CON and decide if it is worth taking a shot with one before you displace the TV.
Again, the thing to start with is the model.
Hope this helps.
Sep 06, 2013 | Sanyo 42 in. LCD TV
Laptop monitor bad color and flickers continuely, but when attached to external monitor, works fine
I'm going to take an educated guess here, because it sounds like the monitor's interface controller is bad. I forgot the name of the thing, but it's a small circuit board that's normally located at the bottom of the panel frame, between the flat ribbon cables and the round hinge cables.
"Inverter Board"
Mar 19, 2013 | Dell LATITUDE Computers & Internet
Samsung ln40b550k1f screen flickers on and off
When the screen flickers on and off it usually comes from the power supply or backlight inverter being bad. For your TV, the backlight inverter and power supply unit are combined. As you can see in the picture attached it's the white part on the right side that has gone bad. You will need to replace that board. LN40B550K1F Samsung LCD TV Repair Guide
Mar 11, 2013 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
FLICKERING BACK LIGHT
Sounds like you have an LCD tv with backlight problems. Check power board for domed capacitors and replace them. next check connections on the inverter boards. they are on the sides or just one side. Becareful there is high voltage output from these boards. If the cable from inverter board is not good to the screen you can get a strobing. the inverter boards may need replaced. or cales to screen may be bad. The panel also could be bad.
Mar 25, 2010 | Televison & Video
My Dell Latitude C400 PC Notebook screen flickers very fast, any ideas? thanks
It can depend on what kind of flickering you are seeing. A very very fast one, that shows more obvious if you look to the side of your screen (instead of directly at it as normal), means your screens 'refresh rate' is most likely wrong.
That's the most likely problem you have, as the inverter will usualy only make a screen flash, not flicker, though they don't usually flash too much before the bulb or inverter can't take the strain and breaks properly.
Sometimes a screens circuit can go slightly faulty (very rare) and cause a slight change in its refresh cycle, and that can cause a high speed flickering too, usually accompanied with a very slight blurring of any images.
The standard setting for a C400 is 1024 x 768 resolution at 60 Hertz, so check your display properties to see that's not been accidentally changed.
Mar 12, 2010 | Dell Latitude C400 Notebook
HP L1720 flickering!
this is common, the display is bad.
all displays, fail. all do. no reason to get angry,
a broken display is worth nearly zero value $0
so how much money will you spend on worthless.?
you can get a new display at Walmart for $65, ,
lines are usually very serious. and is not ever the DC-DC inverter
a bad inverter (< it's power supply) is for the back ground lamps. not data side. the data side is failing and is common, if you twist the screen
it gets worse. ? bingo. data driver connections bad , screen.
IN most cases the part that is bad (screen), costs $100 new. or 50 used
why go there/
Jun 01, 2017 | HP L1720 17 in. Flat Panel LCD Monitor
Flicker
I had the same problem with the flicker. Mine was a Flicker followed by a greenish line through the screen. It got worse then after 2 months the tv stoped working the power didnt come on at all. I Im taking it to bget fixed. The guy said it has somthing to do with a burnt out switch in the unit.
Oct 13, 2007 | Daewoo DSP4210GM 42 in. Plasma Television
Hitachi 51f500(flicker+warp)
Most likely bad convergence IC's! Location numbers should be IK04 and IK05. Generic numbers STK392-110.
Jan 23, 2007 | Hitachi 51F500 51" Rear Projection...
Computers & Internet Logo
49 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
