The red, white and yellow plugs from the reciever will plug into the red, white and green input plugs on the TV. Be sure to select "AV" mode on the TV and not "HDMI". The Green plug on component inputs is the Video input. Otherwise you can find an adaptor that will go to your hdmi ports via the rca jacks!!
I Hope This Help's!!
We Are Here To Help !!
SOURCE: Blue-ray Player HDMI jack to existing TV DVI-HDTV connector
Unless your TV is HDCP compliant (sorry, don't have to research this for you), you may not be able to watch Blu-Ray movies from your Blue-Ray player in 1080p. So first find out if your TV can do HDCP via the DVI port (i doubt it). If it can, you can get an HDMI-to-DVI adapter (you can find them real cheap off Amazon.com)
-Eddie V.
SOURCE: I have a new 52"
I have the same situation....what I have done is connected my Blue ray to the TV via the HDMI connection and the audio to the RTDVD1 via an Optical cable. I find this is the best connection and sound reproduction so far. The input of the RTDVD is the SAT/Optical input and then switch the source to SAT/OPT. You will have to make adjustments in the BlueRay player's audio setup to enable the 5.1 DB digital sound etc.
SOURCE: RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
SOURCE: No VHS playback between DVD/VCR Unit and LCD TV (Both Samsung)
I am having the exact same problem....can anyone help?
SOURCE: I am connecting a RCA
Hi
Thanks for using FixYa. Two things that will cause
the “No Signal” message to come up are - no data available for closed
captioning and a weak signal input. Your TV is in the Closed Captioning Mode.
To turn it off simply bring up the on screen menu and scroll down to the part
that says closed captioning and turn this function off! With the closed
captioning block displayed and the program being viewed is not sending out
closed captioning signals the TV will display, No signal!
If this doesn’t resolve your issue then the problem may be
with the processor failing and it is causing a random read of the EPROM to
display the not available message. I’ll suggest you to run the HDMI from the
PVR (personal video recorder) directly to the TV (mute the TV), and then run
the optical audio from the PVR directly into the receiver's optical in. The
closed captioning is something that is addressed in analog broadcasts, but not
necessarily digital broadcasts
Try using Component cables if this doesn’t make a
difference. After using components cables the issue will be resolved. Please do
accept the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
