Question about Crafts & Hobbies
Need a replacement part for Lionel Holiday Tradition Express - lockon track power connector part#**********
3 Suggested Answers
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
  • 4 Answers
SOURCE: Remote is not working for my Lionel Holiday Tradition Express Train with new batteries. Any suggestions?
I rewired my train this weekend..it now works on my outdoor setup....I found that the circuit board inside the engine had a blown capacitor and the power transitor was fried. I by passed the engine board found that it only would run backwards....went into the tender and taped into the power from tack bypassing the rectifer... By the way the engine does not start up when one uses the remote...there is a 20 second delay before starting
Posted on Nov 29, 2011
Lionel g gauge wont run on track
I think you have solved the problem. Check all the wheels to be sure that they all turn. The locomotive isn't powerful enough to drag a car with a stuck wheel.
Dec 25, 2013 | Lionel Trains Holiday Express G Gauge...
Holiday Tradition Express, engine tender not working. Contacted Lionel Trains, they have no replacement parts or service available.
Best bet is to search the internet for Lionel replacement parts. Try to include as much information in your search.
Dec 03, 2012 | Lionel 11000 Holiday Tradition Express...
What guage wire should I use to connect a train transformer to the O gauge lockons on the train track? thank, E.S
I have used 18ga lamp wire but you can use wire as thin as telephone wire. My rule of thumb is to use thicker wire (lower gauge number) the more motors on the train you are running. 20 or 22ga is generally used by most.
Jul 05, 2012 | Lionel The Polar Express Train Set
Nov 27, 2011 | Lionel 11000 Holiday Tradition Express...
Our Lionel Holiday Tradition Express Set 7-11102 will not move even though all of the other functions work properly
Did you check the reverse switch? Be sure that it is turned ON. If your locomotive still will not run, check that there are no fibers wrapped around the wheel axles or any exposed gears. If none of these fix the problem you will need to take your locomotive and tender to a Lionel Service Station.
Dec 21, 2010 | Toys
I have a holiday tradition express model . for 3-4 seasons it has worked fine ,it has been stored in the original wrappins and box when not in use. today i can't get power to the rails . it seem like...
try to connect from the other side of the track i am not familular with this model but of the track as been switched round maybe it only connects from one side.
I have soldered wires to the tracks before to have a perment connection and then just terminate the wires to the power supply with clips. maybe this is a work round.
I hope this was useful and Happy holidays.
Dec 12, 2010 | Toys
On my Lionel Holiday Tradition Express the handheld remote works yet with the train will not respond. All connections have been cleaned and that is not the problem. I did notice that the wheels on the...
the train does not run in daylight.....when one places the remote over the engine protecting the senor from sun the engine will start 10seconds after the sounds...I was very disappointed that it would not run in daylight. I'm looking for a method to rewire the system to work in daylight....maybe bypassing the control card.
Nov 28, 2010 | Lionel 11000 Holiday Tradition Express...
The train is not responding to the remote.
I had a similar problem with my 11000 Holiday Tradition Express. I cleaned the track with an eraser (pencil-type) and then used a soft cloth to clean any possible residue. After doing this twice, my train is now running.
Dec 04, 2009 | Lionel 11000 Holiday Tradition Express...
Connect the lionel ctc lockon to the track
The lockon is for tubular O or O-27 track. Slide the large part of the clip over the bottom flange of one outer rail....straight track works best and snap the cmaller clip onto the center rail. the two small terminals are your wire connections.
Nov 23, 2009 | Toys
Crafts & Hobbies Logo
123 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
