Question about Copystar CS-1510 Copier
How do I replace the drum and developer in a copystar cs1510? there are no instructions in the owners manual.
Put your finger deep in your *****
Posted on Jul 29, 2009
Black streaks on both side of paper when copy on glass
Throwing the machine away is the best recommendation. You have a bad drum/developer that is leaking some toner. Could be a bad cleaner blade for streaks on the front; fallen toner for streaks on the back. Careful cleaning, replace transfer roller. First, check the condition of the fuser assembly. If the soft roller is bad it will leave toner buildup on the teflon roller, and vice-versa. Start there.
Sep 03, 2014 | Copystar Office Equipment & Supplies
Where can I get a drum for a copystar cs1510?
http://www.digitalsystemcopiers.com/Copystar_CS-1510specs.html
About Us How to Order
Warranty
Contact Us
Email
CopyStar CS-1510 Digital Copier
CopyStar CS-1510 Digital Copier Supply Prices Toner Type Cartridge: Price: $37 Yield:7000 Developer $54.00 per 100,000 copies Drum $107 per 100,000 copies
CopyStar CS-1510 Digital Copier Optional Equipment
Oct 22, 2011 | Office Equipment & Supplies
Kyocera Copystar CS-1820 Black and White Copier fade photocopy on one side of the paper?
Try to re install the cartridge? Also make sure the drum unit & developer unit are connected corretly. Odds are one of the two clips that lock the two parts of the drum unit may be broken....
Jul 19, 2011 | Kyocera Copystar CS-1820 Black and White...
I am a tech and have to replace the drum on a copystar CS 1635. The service manual has been lost so I need the instructions.
open front cover, remove toner cartridge and waste toner tank. unscrew the screw below the developing unit and release the dev unit by pulling the lever. open left cover. from the front remove the screw on your left holding the drum unit. gently pull out the drum unit and replace the new unit using. the reverse procedure to be used.
Apr 20, 2011 | Kyocera Copystar CS-1635 Copier
Copystar cs1510 showing error e70 please help
The E70 its a troubleshooting original placement and memory errors:
1. Remove originals and replace them in the original table when the "E70" or "E71" errors display.
2. Remove originals placed on the original tray and allow the copy job from the plate to complete when the "E72" error displays.
3. Remove originals remaining in the original table when the "E90" error displays, indicating that the memory is full. Press the button with a "%" sign on it, labeled recall, to print the copies of the originals that have already been scanned. When printing completes, place the remaining originals back into the original tray and press "Start" to continue copying.
Hope helps.
Apr 18, 2011 | Copystar CS-1510 Copier
Copystar CS1510 Error E70
Your fuser needs to be replaced
Apr 28, 2010 | Copystar CS-1510 Copier
I replaced the drum in Copystar 1820. What code
1-4-1 Maintenance mode
1) Executing a maintenance item
Press the System Menu/ Counter Key
Select Service Setting using the up/down cursor key
While pressing the start key and the # key press the enter key
Select maintenance mode using up or down cursor keys
Press enter key
Enter the maintenance item
number U-130 using the up/down keys.
The selected maintenance item is run.
Press the back key.
Press the enter key.
Start
End
Run another maintenance
item?
Turn power switch off and back on
U130 Initial setting for the developer
Description
Executes toner install operation.
Purpose
To operate when replacing the process unit.
Method
1. Press the enter key. A selection item appears.
2. Select On using the up/down cursor keys.
3. Press the enter key.
4. Turning the power switch off and back on.
ADDING TONER is displayed and installation of toner starts.
5. After approximately 15 minutes, the installation is completed and the machine becomes ready
.U157 Checking/clearing the developing drive time
Description
Displays the developing drive time for checking or changing a figure.
Purpose
To enter the developing drive time again after carrying out initialization with U020 and to clear the developing
drive time when replacing process unit.
Method
1. Press the enter key. The developing drive time is displayed in minutes.
2. Change the setting using the left/right cursor keys or numeric keys.
Setting range: 0 to 99999
To clear the developing drive time, set the value to 0.
3. Press the enter key. The value is set.
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
I hope this isn't too confusing for you, but this is what has to be done when replacing the Drum Unit (Process Unit Assembly)
Sep 14, 2009 | Kyocera Copystar CS-1820 Black and White...
Is drum, blade and deleloper replacement something I can do myself?
Yes, I would suggest a large table with a plastic cloth, so you don't have to worry about toner spills.
It is a bit messy, but will save you a lot of money.
Word of caution : the drum should come with a white powder on it, this is to lubricate the blade; otherwise it will scrape it and make lines on the drum, in the case it does not have the powder, add some waste toner to it and the blade so it can slide on the drum smoothly.
Also emty the waste toner in a garbage bag and seal after words.
Sep 04, 2008 | Copystar CS-1510 Copier
Printing Too Light
9 times out of 10 when a copier is printing light it is NOT the toner.
when the toner is low the machine will display a message.
can you tell me how many pages this machine has done?
(hold the stop button to get a meter reading)
May 07, 2008 | Copystar CS-1510 Copier
Copystar CS-1510 Copier Logo
235 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
