Question about Vacuums
Roller brush won't turn...the motor runs but wont turn..acts like it is seized up..
    President:
  • 1,124 Answers
The belt may have come of or broke..
Turn the vac over so the bottom is facing up..
Remove the scews in the plate cover that surrunds the brush..
Remove the plate cover..
You will see if the belt is on or if the brush is stuck..
IF the belt needs replacing - put the belt on the motor shaft. Pull out the sude of the brush that the belt goes on and put the belt on..
It might be a little tough going back in place because the belt will have a litlle tension..
Posted on Jul 29, 2009
  • Carl
    Carl Jul 29, 2009
  • 144 Answers
Check your belt. Could be broken or loose.
  • ThinkVacuums
    ThinkVacuums Jul 29, 2009
    Check the belt. Could be broken or loose.
The roller on my DC25 will not turn. I have removed it and cleaned it throughly. The end of the roller opposite the end it comes out of seems to be frozen
The end that seems to be frozen is what turns to spin the brush roll. Try turning the machine on and pull back on handle as you would if vacuuming but do not have the brush roller in the nozzle housing. If the piece the brush roller goes over does not spin the motor may be seized or The belt may be broken.
Jan 06, 2017 | Vacuums
Canister vacuum
Without the make or model... We are speaking in GROSS GENERALITIES... but
ELECTRICAL Trouble...
The light & the BRUSH not working ... when considered TOGETHER.. would indicate a NEED to check your electrical connections...
My best advise would be to:
make sure the cords & wands are fully connected
make sure the (HEAD) motor is running ...
If the motor (brush head) is running... belt looks good and brush is not seized (or jammed)...
You will need to look to the DRIVE PULLEY on the motor OUT-PUT shaft...
Hope this helps
Jul 25, 2016 | Vacuums
How do I remove roller brush, it is seized and there doesn't appear to be anything on it stopping it from turning.
OK, I will assume the motor runs. Usually there are screws holding the roller brush cover (bottom of the machine toward the front). I think mine has four. Remove these and the cover should come off revealing a roller brush and a small rubber rubber drive belt.(Check belt for wear) The roller should come out easily when the belt is slack. There is a shaft running through the roller with bearings on either side to let it spin smoothly. These do wear out, or grit can sometime cause them to seize. Check by spinning the roller. If it spins then it's ok, If it does not then try WD-40 in each end and try to work them free. This is not a permanent solution but it will help. If it is freed up get something like A-1 oil and a few drops of that can help as well.
You might go to the company website and read the FAQ's. They may even have a manual or a diagram of your model.
This is only a guess on my part, but I hope it sheds some light on problem
Apr 18, 2016 | Vacuums
Beater brush on Dyson DC14 getting no power
Hi There,
Alec from VacuumSpot here. The roller on a DC14 does not have a separate power supply the way it works is when the motor is running there is a belt that runs from the motor to the clutch and then another from the clutch to the roller.
As long as the floor selector on the front of the machine is set to carpet it will work when the machine is on.
Without seeing your machine I would suggest that there is something not quite right about the clutch. If I was to take a guess it would be that the clutch to motor belt is broken or slipped off. I have made a video showing how to check the clutch and the brush.
Dec 08, 2012 | Dyson DC14 All floors Bagless Upright...
My roller bush won't turn ever time i put a new
1) you need a little tight the belt, with the bolts of motor.
2) you must shure if the belt if NOT large or short( in both cases the rollers will NOT run. can be slip. or too TIGHT. and BRAKE the motor.
3) the motor you must test for brush, switch, or open winding.
4) put a little lube in the extreme of shaft rollers,see by turning at hand if they run of course unplugged the power cord.
God bless you
Jul 23, 2012 | Vacuums
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Motor runs, brush won't turn, burning rubber smell
Easy to fix. The burning rubber smell is hair in the roller against the belt! Congrats, you have a healthy vacuum, you are lucky! Unplug the vacuum, remove the screws that cover the belt and roller brush. If you are nervous, take pictures with a cell phone or digital camera as you go for re-assembly. ok, pull the long roller out of it's slot and out of the vacuum. cut all hair off the roller and carefully move the belt from side to side to do the same. If the belt slips off, it slips back on easily. If the area is too tight for fingers guide it back on with any long thin wooden object. You can squeeze the belt to narrow it and slide it back over the thin metal rod that spins it from the motor. Slide the roller through the belt and back into it's slots. If it won't slide back on, turn it a quarter turn. Repeat till it does slide back into place. Put the face plate back on-tighten screws, flip it over, plug itr in and it should work!
Sep 05, 2011 | Bissell Vacuums
The belt on my Dyson is making a terrible loud grinding sound after I removed the brush roller.
The sound is the clutch mechanism. That is a safety feature. It sounds like you have trapped the belt when you reinstalled it. If not, the brush roller bearings may be seized?
Take it apart again, spin the brush roller in your hand. Make sure it is free. When you reassemble it, before you refit the sole plate, turn the brush a few times with your fingers to make sure the belt finds its home on the roller. Only then refit the sole plate. Turn it again when fitted before you run it to make sure the brush is turning freely.
Then, make sure the clutch is engaged, see this article for more on clutches: DC14 clutch and brush roller
Feb 02, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Fantom twister wont work light is on
When you say, "just stopped", did the MOTOR stop operating and there's no sound from it at all? Or, is the motor still working or sounds like it does, and it stopped vacumning?
If the MOTOR stopped, most likely there is a short somewhere in the connection at the motor. Think 'repair shop'.
If the motor still runs and there's no VACUMN ACTION, think Roller Brush which operates by virtue of a rubber belt. Turn the machine on its side and turn it ON, keeping FINGERS !AWAY! from the roller area. If the Roller Brush is not moving it may be that the belt has slipped off or is broken or simply too loose to turn the Roller. Also sometimes debris such as strings, long hair, carpet strands/fibers will become wrapped around the roller especially next to the roller bearing/brace points, to the point of binding so tightly that the roller will no longer be able to actually roll which would now prevent it from 'Vacumning' or sweeping dirt and such up into the vortex of the vacumn chamber. In which case, !!UNPLUG!! the machine, use small scissors to cut away the material wrapped around the roller paying particular attention to the brace point areas.
Apr 20, 2009 | Fantom Vacums FM780 Twister 700LX Upright...
M1300 i dirt devil brushes wont roll
Ok I would say the belt burnt into if you can turn it on and the motor runs it is the belt . I would pull it apart and replace the belt.
Feb 25, 2009 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Vacuums Logo
204 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
