Question about Motorola Mobility W375 Cellular Phone
When I press "0" key on my mobile, I get "60" displayed instead !
It's a Nokia 9300 Communicator,
the "zero" cover key is not working properly, displaying 60 instead of 0.
I checked both the fast dialing and the regional settings:
nothing is assigned to this key.
I wonder, is it a problem in the circuit under the keypad?
I took off the cover's skin and keys, and tried to press 0 directly:
same thing.
I have a little knowledge in electronics, I can try more,
so please tell me what to do next.
Thank you in advance.
  • 1,305 Answers
Do you have phone insurance with your cell carrier? if so, it may be a way to get a replacement inexpensively.
Posted on Jul 29, 2009
My nokia 9300's screen went blank.please give me necessary support on how i can remove it without depending on the communicator screen. infact the outer screen is ok but the communicator screen is what...
First of all, your question is not clear enough for me,but let me conclude what you are saying.
Loosing the internal display depends on LCD and Flex connector that connects the upper and the lower panel. But most problem that i encounter about this mobile is the replacement of Flex connector due to some cut areas along its parts. Outer display is separate from internal display so possible to see the outer display.
This mobile need to fix by an experience techinician because fixing this problem is more complicated to work with, more likely on dismantle,replacing and disassembling the parts than any small type of mobile.I may advice you to bring it to an authorize service center to make this problem.
Regarding your personal data that stack inside your phone, You need a tool to recover all of your important data.Download this link to copy all files coming from the phone and all the way to your computer.
NOKIA PC SUITE DOWNLOAD
Follow this procedure :
1. dowload the link above and locate the download file were save.
2. run the application and install the program,just follow the instruction and wait till the installation is done.
3. open the application and connect the phone thru the computer using data cable or usb cable.
4. wait until the mobile is recognize by computer.
Now you can see all data stored from phone to computer,you can download and transfer them to another phone if applicable.
Please correct me if this is what you try to say.
Best Regards.
Jul 04, 2011 | Nokia 9300 Handheld
Tip
Nokia codes and tricks
Most Popular and Useful Nokia Codes How its done: Go to standby mode (the state where your wallpaper, clock, and operator logo are displayed at the same time - press the red button on your keypad),then press the secret code. Example: if you press Quote: *(asterisk) #(number sign) 0(zero) 6(six)#(number sign) it will show you your phone's IMEI/serial number. The CODES: *#06# - displays the unique serial number or IMEI number *#0000# - shows the firmware or software version details *#2820# - Bluetooth (BT) device address press and hold the ZERO (0) button - brings you to the homepage of your wap/gprs press and hold the MENU button - launch thephone's task manager. you can then switch between active programs or terminate a running application by press the CANCEL/DELETE (c) button. *#7780# - restores user defined settings to factory default settings. programs, calendars, and contacts are unchanged. you will be ask to input your security or lock code to proceed with the restoration. *#7370# - reprograms your phone memoryto factory default. all files will be deleted. you will be ask to input your security or lockcode to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead. turn ON your phone while holding together the green (call) button, *, 3 - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: applicable only to Nokia Series 60 2nd edition and above phones (N6600 and up). *#7370925538# - reprograms your phone's wallet application. all information on your wallet will be erased and the wallet code will be removed.
on Jul 10, 2011 | Cell Phones
How to format of nokia 9300i
Welcome to Fixya
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Have a good one!
Mar 26, 2011 | Nokia 9300 Handheld
I have a nokia 9300 mobile now i m having a problem in my cell problem is when used front display it get pleas close cover tell me answer quickly
Hello Abhay,
There is no problem in your phone.
You can not view both the display at time.
This feature is not provided in phone by the Nokia.
So you have to access one display at a time.
Mar 19, 2011 | Nokia 9300 Handheld
How to format my nokia 9300i
CRTL + Shift + F
Oct 14, 2010 | Nokia 9300i Cellular Phone
How to format nokia 3310
*(asterisk) #(number sign) 0(zero) 6(six) #(number sign)
The CODES:
press and hold the MENU button - launch the phone's task manager. you can then switch between active programs or terminate a running application by press the CANCEL/DELETE (c) button.
*#7370# - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead.
Apr 16, 2010 | Nokia 3310 Cellular Phone
Unable to delete call lists in my nokia 9300 What should i do? Is it a software problem?
What do you mean by Call list? If you mean the list which comes up when you press the GREEN KEY then it can not be delete from there! Open the communicator Press the TELEPHONE KEY then press RECENT CALLS Then select the tab you desire then click clear all.
If you want to clear the Call Log then open the communicator Press Ctrl + Shift + L & Call log will appear then Press Ctrl + D Enter the date before which you want to clear the Call log & press clear.
Jun 08, 2009 | Nokia 9300 Smartphone
Problem is how format my nokia 9300 communicator
you want to HARD FORMAT, switch off your mobile phone 1st, then press and hold 3 keys at a time star key, green dial key, and no. 3 key. then switch on your phone.
do not unhold all three key's until nokia's logo come's [hand shake] . it's done. you have to select your city. mean's your phone is virus free now.
[get backup of your contacts and messeges before formatting or you will lose your data]
Mar 21, 2009 | Nokia 6681 Cellular Phone
NOKIA 9300 FORMATING CODE
this code is not working
Feb 28, 2009 | Nokia 9300 Handheld
Formatting nokia 9300 comunicator
how code format nokia 9300 comunicator
Feb 23, 2008 | Nokia 9300 Smartphone
Motorola Mobility W375 Cellular Phone Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
