Question about GE Profile Spectra JGBP90 Gas Kitchen Range
My oven does not heat up to the temperature indicated by the control (e.g., 350 gets 275 in the oven. How do I adjust the control?
  • 162 Answers
Turn on to 350 pull knob off rotate to 275 push knob back on
Posted on Jul 29, 2009
My wolf red ch-6-29-ft22l-lbl the oven has to b set at 425 to maintain 350 is this a tstat problem or gas valve issue ?. when set on 350 the flame cuts back at 275 and holds there..
it could be a thermostat problem as it controls the gas valve settings
As it is gas , call in the gas technician for the unit and have it diagnosed and fixed properly
Mar 07, 2016 | Kitchen Ranges
My old admiral oven doesn't get to the temperature I want, could it be the oven temperature sensor?
  1. You can do a simple at-home test.
  2. Purchase an inexpensive oven thermometer (the kind that hang from the rack are great but whatever is designed for oven).
  3. Then set your oven on 350 and wait for oven light to go out (indicating it is at temperature). Compare the temperature on the thermometer (it should say 350 but sounds like your results will be less).
  4. If it is not the same temperature you have SOME adjustment that can be made. Most oven temperature control switches have the ability to adjust/calibrate. Depending on make and model you may be able to pull the temperature adjustment knob off and see a screw and a slot. Loosen the set screw and turn the post slightly then re-seat the screw.
  5. Repeat the test on step 3 again and see if you are closer.
  6. If it got worse, loosen screw and turn the other way (and re-test).
  7. If it got better but not quite right, repeat the procedure.
  8. If you are unable to adjust to get the temperature correct you may have a faulty temperature sensor.
Nov 03, 2014 | Ovens
My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
Jan 19, 2012 | Whirlpool Ovens
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
The temperature in my oven is not accurate.... If I set it for 350, it pre-heats and then buzzes [to let me know it's reached temp]....but the temperature is NOT 350; rather, it is at 275 [I have a...
Your oven's manual should tell you how to adjust this. The manual should also have a trubleshooting chart. Also remember, your temperature sensor may be going bad and will need to be replaced. For now, you can set the temperature 75 degrees higher to get the correct temperature you need.
Sep 15, 2011 | Whirlpool Electric Range
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Whirlpool 465 oven temp
Go to Calibration mode and adjust the temperature up by 10, 20 or 30 degree. This is in each manual.
Jan 11, 2008 | Whirlpool GS460 Gas Kitchen Range
Temperature
Your manual should tell you how to adjust the temp. up or down.  If this doesn't work then replace the oven temp sensor.
Oct 21, 2007 | Jenn-Air SVE47100 Slide-In Electric...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
431 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
