Question about LG Washing Machines
Where can I find the belt tensioner on a LG FUZZY LOGIC 8.5KG WF-T857 washing machine
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 539 Answers
The motor id mounts are slotted so lossen those and you can adust the belt tension that way, warning the belt id supposed to be loose if over tightened you will ruin the bearins in a very short space of time
Posted on Mar 02, 2018
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
  • 5613 Answers
SOURCE: Lost manual to LG washing
I do not know this model. However, on other top load LG washers, the powdered detergent goes in a box at the back (top) of the washer, and the fabric softener when diluted gets poured into a spot near the left side of the top of the washer. (The bleach goes near the front of the washer.) For front-loading washers, the detergent and fabric softener are poured into the detergent drawer. The largest compartment is for detergent (wash cycle) and is usually on the left. The smallest compartment is for fabric softener.
Manuals for most LG appliances are available at their site. Start at http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WF-T502C&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WF-T502C&initialTab=documents&targetPage=support-product-profile . The manual is in a DjVu format.
A partial manual is also available here: http://monitor.diplo-best.com/review/LG/WF-T502C . You will need to review the washer or enter a code.
I hope this helps.
Posted on Jun 13, 2011
FitzOriginal
  • 842 Answers
SOURCE: my LG washing machine model-fuzzy
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Posted on Jun 23, 2011
TheMobilian
  • 8220 Answers
SOURCE: I have a LG fuzzy logic the problem is that its not stopping the water input its over flowing ....
When you press the "SPIN SPEED" button and "SOIL LEVEL" button the water level frequency should be above 246. If the water frequency level fails to reach 246 in 8 minutes you will get an IE error or inlet error. You would need to check the water valve, water pressure, etc.
How does the machine know if the water level is complete? Water level switch right? So obviously the control is timing the amount of time it takes till the water level switch kicks off. If it takes more than 8 minutes we have a problem don't we? Therefore if something is partially blocking the tubing from tub to switch that might throw off the water level switch. It is located on the main control assembly and has the rubber tube connected to it. The control board uses this to determine water frequency level. Just blowing the sediment out of that tubing will cure the IE error IF everything else mentioned is all good. I meself would do that first before replacing any parts.
LG WASHER MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 04, 2012
Fuzzy Logic 8.5Kg WF-T857 Turbodrum. How do you clean your machine and can you replace the fluff pockets?
Your owner's manual will show the amount of bleach your size tub requires. Run the machine on normal cycle that you use but do not add washing powder or fabric softener, only the bleach.
When the cycle has ended, open it up and allow to air dry.
The lint filters are replaceable and are available from your nearest LG service center or distributor.
Apr 16, 2015 | LG Washing Machines
Lg fuzzy logic manual wf-t552th
I have an LG WF-T502C T552.
It makes a loud squeal noise on the spin cycle.
I am thinking of replacing the belt. Is it possible it could be the bearings or the transmission?
Dec 24, 2013 | Washing Machines
Lg fuzzy logic 8.5kg WT T857 washing machine
THERE IS THREE POINT TO CHECK.
O1 .INLET VALVE SHORT CI-CUTS
02. PRESSER SENSOR SHORT CIRCUITS
03 .PRESSER SENSOR TUBE MIGHT BLOCKAGE WITH DUSTY,
Dec 13, 2013 | Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
Lg fuzzy logic model wf-t7014pp. seems like spinner belt is worn, loose, how do i replace it or tighten the belt
plz replace the belt if it is worn ..its better to take preventive maintenance than breakdown maintenance
Aug 18, 2011 | LG Washing Machines
Fuzzy Logic 7.5 kg WF-T753A not agitating.
short answer, its not easy. i believe its run by a gear assembly. i would hire a pro to at least diagnois it.
Nov 06, 2009 | LG WFT1071TP Top Load Washer
Washing Machines Logo
49 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
