Question about Acer Office Equipment & Supplies
When I try to scan I get a parameter failed message
    Scholar:
  • 143 Answers
Every scanner has its drivers and softwares included so to give any solution it is needed to know who is a manufacturer and what  model it is. may be DPI are outside the max or min value.
Posted on Jul 29, 2009
How to diagnose which door is causing the door ajar warning on dic for 08 pontiac g6 4cyl 4dr
It should tell you which one .
Driver Door Ajar Malfunction
Passenger Door Ajar Malfunction
If not a scan tool would be the best way.
Ignition ON, observe the scan tool Driver Door Ajar Sw parameter while opening and closing the driver door. The parameter should change between Door Closed and Door Ajar
? If the parameter does not change, refer to Driver Door Ajar Malfunction.
With the passenger doors closed, observe the scan tool Door Ajar Switch parameter while opening and closing each door. The parameter should change between Door Closed and Door Ajar.
? If the parameter does not change, refer to Passenger Door Ajar Malfunction
Ignition OFF, disconnect the harness connector at the driver door latch.
Test for less than 5 ohms between the ground circuit terminal 8 and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify the scan tool Driver Door Ajar Sw parameter is Door Closed.
? If not the specified value, test the signal circuit terminal 6 for a short to ground. If the circuit tests normal, replace the BCM.
Install a 3A fused jumper wire between the signal circuit terminal 6 and the ground circuit terminal 8. Verify the scan tool Driver Door Ajar Sw parameter is Door Ajar.
? If not the specified value, test the signal circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the BCM.
If all circuits test normal, test or replace the driver door latch
Dec 26, 2016 | Pontiac Cars & Trucks
Code Error0x0000073
found this on net
STOP: 0x00000073 (parameter, parameter, parameter, parameter) CONFIG_LIST_FAILED
Explanation: This is a Windows 2000 Executive character-mode STOP message. It indicates the system configuration link list failed. One of the core system hives is corrupted or unreadable, or some critical Registry keys and values are not present.
User Action: If this is the first time you have booted after installing new hardware, remove the hardware and boot again. Check the Microsoft Hardware Compatibility List to verify that the hardware and its drivers are compatible with Windows 2000. For information about the hardware, contact the supplier. If you are installing Windows 2000 for the first time, check the Windows 2000 system requirements, including the amount of RAM and disk space required to load the operating system. Also, check the Hardware Compatibility List to verify that the system can run Windows 2000. If Windows 2000 is loaded and no new hardware has been installed, reboot with recovery options set to create a dump file. If the message continues to appear, select the Last Known Good option when you reboot. If there is no Last Known Good configuration, try using the Emergency Repair Disk. If you do not have an Emergency Repair Disk, contact your technical support group.
Nov 19, 2013 | Computers & Internet
Incorrect parameters when scanning
all setting getting to default then try again
May 18, 2012 | HP Photosmart 4180 All-in-One Printer
How do I correct this message?: Exception processing Message 0xc000007b Parameters 0x759B023C 0x759B023C 0x759B023C 0x759B023C It happens when a video (usually a .WMV file) tries to play in the...
These error messages may be caused by the WORM_KLEZ.E virus, or one of its variations.
Go to trendmicro.com and run their free online virus scan. It can take a couple of hours to run and you must be connected to the internet.
It that doesn't do it let me know.
Jan 21, 2010 | Google Chrome
Problem: KERNEL_DATA_INPAGE_ERROR Technical information: ***STOP: 0x0000007A (0xC0403638, 0xC0000056, 0x4277F860, 0x806C7913) ***acpi.sys ? Address 806C7913 base at 80692000, DateStamp 49c01a37
The KERNEL_DATA_INPAGE_ERROR bug check has a value of 0x0000007A. This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
Parameters The four parameters that are listed in the message can have three possible meanings. If the first parameter is 1 or 2, or 3 and the third parameter is 0, the parameters have the following definitions.
Parameter Description 1 The lock type that was held (1, 2, or 3) 2 The error status (usually an I/O status code) 3 If Lock Type is 1: the current process
If Lock Type is 2 or 3: 0
4 The virtual address that could not be paged into memory
If the first parameter is 3 (and the third parameter is nonzero) or 4, the parameters have the following definitions.
Parameter Description 1 The lock type that was held (3 or 4) 2 The error status (typically an I/O status code) 3 The address of the InPageSupport structure 4 The faulting address
Otherwise, the parameters have the following definitions.
Parameter Description 1 The address of the page table entry (PTE) 2 The error status (usually an I/O status code) 3 The PTE contents 4 The faulting address
Cause Frequently, you can determine the cause of the KERNEL_DATA_INPAGE_ERROR bug check from the error status (Parameter 2). Some common status codes include the following:
  • 0xC000009A, or STATUS_INSUFFICIENT_RESOURCES, indicates a lack of nonpaged pool resources.
  • 0xC000009C, or STATUS_DEVICE_DATA_ERROR, typically indicates bad blocks (sectors) on the hard disk.
  • 0xC000009D, or STATUS_DEVICE_NOT_CONNECTED, indicates defective or loose cabling, termination, or that the controller does not see the hard disk.
  • 0xC000016A, or STATUS_DISK_OPERATION_FAILED, indicates bad blocks (sectors) on the hard disk.
  • 0xC0000185, or STATUS_IO_DEVICE_ERROR, indicates improper termination or defective cabling on SCSI devices or that two devices are trying to use the same IRQ.
These status codes are the most common ones that have specific causes. For more information about other possible status codes that can be returned, see the Ntstatus.h file in the Microsoft Windows Driver Kit (WDK).
Another common cause of this error message is defective hardware or failing RAM.
A virus infection can also cause this bug check.
Resolving the Problem Resolving a bad block problem: An I/O status code of 0xC000009C or 0xC000016A typically indicates that the data could not be read from the disk because of a bad block (sector). If you can restart the computer after the error, Autochk runs automatically and attempts to map the bad sector to prevent it from being used anymore.
If Autochk does not scan the hard disk for errors, you can manually start the disk scanner. Run Chkdsk /f /r on the system partition. You must restart the computer before the disk scan begins. If you cannot start the computer because of the error, use the Recovery Console and run Chkdsk /r.
Warning If your system partition is formatted with the FAT file system, the long file names that the Windows operating system uses might be damaged if you use Scandisk or another MS-DOS-based hard disk tool to verify the integrity of your hard disk from MS-DOS. Always use the version of Chkdsk that matches your version of Windows.
Resolving a defective hardware problem: If the I/O status is C0000185 and the paging file is on an SCSI disk, check the disk cabling and SCSI termination for problems.
Resolving a failing RAM problem: Run the hardware diagnostics that the system manufacturer supplies, especially the memory scanner. For more information about these procedures, see the owner's manual for your computer.
Check that all the adapter cards in the computer are properly seated. Use an ink eraser or an electrical contact treatment, available at electronics supply stores, to ensure adapter card contacts are clean.
Check the System Log in Event Viewer for additional error messages that might help identify the device that is causing the error. You can also disable memory caching of the BIOS to try to resolve this error.
Make sure that the latest Windows Service Pack is installed.
If the preceding steps do not resolve the error, take the system motherboard to a repair facility for diagnostic testing. A crack, a scratched trace, or a defective component on the motherboard can cause this error.
Resolving a virus infection: Check your computer for viruses by using any up-to-date, commercial virus scanning software that examines the Master Boot Record of the hard disk. All Windows file systems can be infected by viruses.
Jul 12, 2009 | Microsoft Windows Vista Home Premium with...
I need to add daytime running lamps to an 08 exlorer u.s. version non fleet. any suggestions?
All you have to do is carry it to your dealer and have them install there IDS scan tool and access programmable parameters in the smart junction box and turn on the feature.
Here is a copy of a broadcast message from Ford(sorry for the caps I just copied and pasted) on this:
20328 2006-2008 EXPLORER 4DR/MOUNTAINEER/2007-2008 EXPLORER SPORT TRAC - DAYTIME RUNNING LAMP ACTIVATION/DEACTIVATION
SOME 2006-2008 EXPLORER 4DR/MOUNTAINEER, AND 2007-2008 EXPLORER SPORT TRAC VEHICLES MAY HAVE CUSTOMERS THAT DESIRE TO ACTIVATE OR DEACTIVATE THE DAYTIME RUNNING LAMPS (DRL). THE FEATURE HAS BEEN ADDED TO THE IDS AND PDS SCAN TOOLS AS A PROGRAMMABLE PARAMETER. THE PROCEDURE IS TO: SELECT MODULE PROGRAMMING FROM TOOLBOX, SELECT PROGRAMMABLE PARAMETERS, EXTERIOR LIGHTS. DRL WILL BE ONE OF THE SELECTIONS WITH ENABLE/DISABLE AS OPTIONS. NOTE: THIS IS NOT A WARRANTABLE REPAIR.
EFFECTIVE DATE: 07/03/2008
Mar 10, 2009 | 2008 Ford Explorer
AGV 8 (build 233) Installation
Make sure all other antivirus software is removed before you try to install it.
Also, run a scan for existing infections with an online scan like TrendMicro = http://housecall.trendmicro.com or
Panda http://www.pandasecurity.com/activescan/index/?track=1&Lang=en-US&IdPais=63
Feb 03, 2009 | Microsoft Windows XP Home Edition
Trying to scan multiple items and email as one file
Press function- fax parameters-key opp mode- put password in- touch fax parameters- go to 183- select multi - ok.
now you can scan what you want
Jun 26, 2008 | Panasonic DP-C213 Color Copier
Scan to email
If you go to the manufacturers website they should have the software you need for free or they might charge you for it. I hope this helps =)
Feb 18, 2008 | Panasonic Workio DP-4530 Copier
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
