Question about HP Pavilion N5150 Notebook
When I try to power up the machine, the green power switch blinks a few times and the fan runs for a few seconds then it goes dead.
    President:
  • HP Master
  • 1,996 Answers
Start here, then see also here, here and here for help troubleshooting this error.
Your home support page here.
A generic startup troubleshooter here.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 29, 2009
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Jul 06, 2013 | Televison & Video
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
URGENT! My computer doesn't switch on and Ihave a tight schedule.
please try a different ac-adapter, since its most likely defective.
if the powerled just blinks 1 time it usually indicates that the battery is empty and need to be charged.
May 29, 2009 | Sony VAIO PCG-K35 Notebook
Starts to power on,then shuts down
Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem.  The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down.  Called tech support and they asked if I had cleaned the filters. I did it, and it worked great.  Check the manual for where the filters are and hit them first before getting a new bulb.  Hope it helps!
May 24, 2009 | Sanyo PLC XF10NZ Multimedia Projector
Green spots/pixels at top of TV screen
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
May 05, 2009 | Pioneer PureVision PDP-503CMX 50 in....
I have a similar problem with the Sony 60" wega SXRD rear projection TV. The green light blinks on the power/display LED and the picture comes on for a few seconds and then the screen goes black . Then the...
I believe 4 blinks is fan error. You can take back off and watch fans in particular the fan for the lamp (this one goes out the most) The TV has a sensor so it knows if the fan turns.You can take a pencil and use it to spin fan sometimes that will jump start it (not a permanent fix just a test). You can try cleaning dust off fan and replugging the connector on the wires coming from fan.Might fix it if not fan will need replacement.
Apr 27, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV won't come on. Standby goes green,then goes red blinks 3 times
3 flashes means the lamp door is not on correctly or the lamp door switch is broken.
Apr 08, 2009 | Sony Grand WEGA KF-50WE620 Television
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
HP Pavilion N5150 Notebook Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
