Question about Canon I960 InkJet Photo Printer
Three yellow flashes then one green. Printer will not print. Says "check to see if plugged into computer and on." Sometimes says "paper jam" (no jam viseable.
    President:
  • 2,306 Answers
Three flashes says that there is still paper or paper scrap inside. Might be a small scrap, hard to see, or sensor arm damaged when earlier jam removed.
Posted on Jul 29, 2009
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
Canon ip100 portable printer ink cradle stuck on right hand side
I had this same problem. Count the number of blinks in sequence of the error light. it will flash green and yellow, and then just straight yellow for a number of flashes, then it will flash green again and the same number of yellow flashes again. Here is the diagnostic guide.
Two flashes: Printer is out of paper. Paper does not feed
Three flashes: Paper jam
Four Flashes: The Print Head Lock Lever is not locked properly / Ink tank is not installed properly. / Ink may have run out
Five flashes: Print Head is not installed./ Print Head is defective
Eight flashes: Ink absorber is almost full
Nine flashes:No response from connected digital camera or video camcorder/Connected digital camera or video camcorder is not compatible with this printer./PictBridge compliant devices are attached to both Direct Print Port and Bluetooth Unit Connector
Eleven flashes: Automatic Print Head Alignment failed
Twelve Flashes: Low battery level
Fifteen Flashes: Ink tank cannot be recognized
Seventeen Flashes: Ink has run out
Eighteen Flashes: Printer detected ink out condition
Nineteen Flashes: A USB hub is connected
Mine had 10 Flashes and the Print Carriage, was bad. Cost almost as much as another printer so thats what I did. I did take it apart and got it unstuck, but still didn't work.
Mar 10, 2014 | Canon iP100 Portable Printer
Printer will not print in black was the first problem and now after less than a minute after turning on it has the light for 'on' flashing green and amber constantly
Try this:
1- Pull the cartridges out, restart printer then reinstall the cartridges again
2- The blinking can mean any of these: paper out, paper jam, cover open, printing error. Please check that there is enough paper, no paper jam (sometimes even the smallest piece of paper will cause that error, then restart both (the printer and the computer)
Best of luck
Jun 12, 2010 | Canon BJC S300 InkJet Printer
My MP510 was just printing fine then went to rear feed and now all I get is a flashing green and yellow lights
review this to determine your problem.. If all else fails simply unplug your printer wait a minute and plug back in.
Handling Error Messages
When a printer error occurs, the POWER/ERROR lamp flashes.
The number of flashes indicates the type of error that has occurred.
Count the flashes and take the appropriate
action to correct the error.
Number of Flashes
Possible Cause
Try This
Two flashes Printer is out of
paper/Paper does
not feed
Reload paper in the Sheet Feeder or Cassette and press the RESUME/CANCEL
button.
Three flashes Paper jam/Paper
Output Tray is
closed
Clear the jammed paper, reload paper in the printer, then press the RESUME/
CANCEL button. If the Paper Output Tray is closed, open it.
See “Paper Jams” on page 72.
Four flashes Empty ink tank Press the RESUME/CANCEL button to resume printing with an empty ink tank.
Replace it with a new ink tank immediately after the printing. It may damage the
printer if you continue printing with an empty ink tank.
See “Replacing an Ink Tank” on page 42.
Five flashes Print Head not
installed/Print
Head not installed
correctly/Defective
Print Head
Install the Print Head. If the Print Head is already installed, remove the Print Head
and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact the Customer
Care Center.
Six flashes Inner Cover is open Close the Inner Cover and press the RESUME/CANCEL button.
Eight flashes Waste ink absorber
almost full
The printer has a built-in waste ink absorber for the ink used during Print Head
Cleaning.
Eight flashes indicates that the waste ink absorber is nearly full.
Press the RESUME/CANCEL button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact the Customer Care
Center.
Nine flashes A specified period
of time has elapsed
without receiving a
response from the
digital camera/The
digital camera or
digital video
camcorder
connected is not
compatible with
this printer
Disconnect the camera cable, press the RESUME/CANCEL button and reconnect
the cable.
If the error is still unresolved, there is a possibility that you are using a digital
camera or digital video camcorder that is not supported by this printer. Use a
digital cameras or digital video camcorder compatible with this printer
Mar 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Paper jammed. pulled out. now yellow light flashes. runs, but no print
check the paper path, specially where the paper is being pickup. it might still have a small peice of paper stuck in the path. pull out the paper tray. can check the paper path in the front of the printer.
use a flash light if you can not see inside.
unplug it printer after you finished. wait 10 sec and plug it back in. that will clear the printer of any remaining print job, and rest the printer.
if this solve your problem, please rate the answer.
thank you
Oct 14, 2008 | HP DeskJet 5550 InkJet Printer
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
If paper has jammed in the printer, clear the jam, replace the paper in the printer
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
Problem with printing
Sorry the manual doesn't help much either... this is what it says, "POWER lamp flashes alternate green and orange Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on. If the problem remains, contact a Canon service representative."
You could try the following reset code which works when reseting after emptying the waste ink tank:
Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope it helps
Oct 03, 2006 | Canon i80 InkJet Printer
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
Canon I960 InkJet Photo Printer Logo
141 people viewed this question
old marine
old marine
