Question about Cell Phones
Cannot find the bluetooth function,cheers - Cell Phones
  • Vinay Tevatia
    Vinay Tevatia May 11, 2010
    It is like finding a needle in the hay stack. There are a million phone models. Which one is yours. Who does not find the bluetooth? You on your phone or you can not find other bluetooth devices on your phone or other bluetooth devices cannot find your phone. Please elucidate.
  • Cell Phones Master
  • 805 Answers
Dear u hadn't mentioned any brand no or model no to ur phone. plz inform it first.
Posted on Jul 30, 2009
Hi there, I have an Advent Modena M100 and want to put bluetooth on it - how please? Cheers!
According to: http://www.uktsupport.co.uk/advent/laptop/modena100.htm
it was an OPTION (not a STANDARD) feature to have BlueTooth support.
So, you may already have BlueTooth capability.
If not, then for about $15, purchase a small BlueTooth device that connects to one of the USB ports, to add BlueTooth functionality.
Jul 18, 2011 | Computers & Internet
Before, I can send and receive files using the bluetooth in my pc.But now, I cannot receive any files from my mobile to my pc.Theres a message that appears like this "Windows was unable to transfer...
Hello Mylenejavier,
To Send and Receive file using Bluetooth requires the following considerations:
Make sure your Bluetooth drivers and adapters for your Notebook are up to date.Make sure the device driver of your phone is installed in your Notebook.Make sure that the Bluetooth function on your Notebook is switched on properly.If these steps are not work for you, dial my toll-free number +1 (833) 493-0111 . I'll Surely help you.
Cheers,
John
Sep 12, 2017 | ASUS Eee PC 900 PC Notebook
How do you put this bluetooth in discovery mode?
Firstly, your headset must be turned off. Then, press the call control (or multi-function) button until the blue and red leds flash alternatively. Then, make the device you want to pair your headset with search for devices. Select your headset (its name will be shown). If a passkey (or PIN or pairing code), enter '0000' (four zeros). Bear in mind that your headset is kept in pairing mode (the blue and red leds flashing) for a couple of minutes only. If you, somehow, miss the pairing procedure during such a period, you'll have to start it over.
Hope it works for you.
Cheers! Carlos
May 07, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How you pair you headset with your pc
With your headset fully charged, and turned off, press and hold the multi-function button, until the blue and red leds flash alternatively. It is now in paring mode. Now, make your PC bluetooth application (don't know which bluetooth stack it has), search for other devices, Select 'MILOS-9', and, if a PIN (or passkey, or pairing code) is requested on your PC, enter '0000' (four zeros). The blue led will flash three times, indicating successful action. If the pairing procedure fails, turn your headset off, wait for 10 seconds, and start it over. From now on, you will need just to turn the headset (and the PC bluetooth hardware) on. They should automatically connect to each other. If they fail to do so, try to right-click on 'MILOS-9', on your PC's bluetooth device list, and select 'Connect'.
Hope you are able to sort your problems out.
Cheers! Carlos
May 06, 2010 | Hagenuk Anycom MILOS-9 Bluetooth Headset -...
NO DEVICE
the machine doesnt have a blue tooth device installed thats all,They make the machines with the option of expanding to new device functions as standard then they can add the components you need ie blue tooth,theres a button but no device installed,you will have to buy a blue tooth device to install on the machine,
Hope this helps Misterdj
I brought a set of dongles for my bluetooth function for about $25 NZD recently,Cheap and cheerful but has limits too so check out the functions you want with bluetooth and go shopping,
May 05, 2010 | Acer Aspire 4720 Notebook
The bluetooth turns on using FN + F11 it should turn the wireless too but doesn't MSI U100
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
�� Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
�� Bluetooth LED indicator glows blue when Bluetooth function is enabled.
�� Both LED indicators glow green and blue at the same time when both
functions are enabled.
�� Both LED indicators go out when both functions are disabled.
�� Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
Dec 02, 2009 | MSI U100-001US Netbook
Bluetooth not functioning for win XP PRO
open the cover on the back and get the blue tooth card number from HP.com you will need your model number from the bottom of your machine,
once you have both then it should be straight forward,
Cheers MISTERDJ
Aug 16, 2009 | HP Pavilion dv1000 Notebook
Cant connect my ex 10 to my x300 head unit
Hi Jared,
The EX-10 was never intended to be an accessory to the IDA-X300, but should work with FM modulation like any other radio, by making sure the FM frequency is set the same on both units. There are four preset channels in the EX-10 but you can change each one to any frequency.
As for the bluetooth mic connection, you must have that connected for the bluetooth to work. You are better off installing a KCE-400BTi handsfree kit to get better functionality, increased phone compatibility, increased audio quality and the ability to use all of the newer iPods (Gen 2 iTouch, Gen 4 Nano and iPhone 3G).
Hope it helps,
Marcel.
Jun 21, 2009 | Alpine eX-10 iPod Controller with...
Hiding iphone 3g when bluetooth is switched on
Hi!  The bluetooth feature on the iPhone is currently limited by Apple to the headset profile and will only function with bluetooth headsets. File transfers, object push (which are the BT profiles exploited by bluejacking) are not activated.
It is not visible to other devices so you dont have to worry. :-)
Nov 21, 2008 | Apple iPhone 3G
How to connect my mobile with my logitech handsfree via bluetooth
To connect:
- Make sure the headset is charged and turned off.
- Hold the multi-functional button for 7 to 10 seconds to set pairing mode. Pairing mode is indicated by de led flashing blue-red.
-Now connect from your phone by selecting discover devices, or something (do not own a L6i). It will find your headset.
-Select the headset and select 'pairing'. Passcode = '0000'
If pairing is successful, the flashing light will change.
Mar 27, 2008 | Logitech Bluetooth Wireless Talking Kit...
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
