Question about Kenmore Dryers
Heating is out in Dryer and can't find Dryer Model #
  • 1,305 Answers
If you open the door, alot of times there is a ID sticker on the door jamb of the dryer. If not, look on the back side of the machine.
If no luck, give us the brand name and a model if it's got a name too...
and we'll see how we can help!
K
Posted on Jul 29, 2009
Does it have a heating element
Yes, as with all dryers, this unit has a heating element. This site: http://www.searspartsdirect.com/partsdirect/part-model/Fisherpaykel-Parts/Dryer-Parts/Model-DEGX196010B/3068/0151200/P0606083/00006?blt=06&prst=&shdMod= has a diagram of the dryer including the pair of heating elements. See part 3 in this Dryer Base diagram.
I hope this helps.
Aug 19, 2014 | Fisher and Paykel DEGX1 Electric Dryer
Dryer not heating
Hello there and welcome to fixya
Here are the most common things that will need to be checked with a meter to ensure there is continuity on these parts no continuity means that the part is bad and needs replacement ok?
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer
Oct 14, 2013 | Amana Dryers
KENMORE DRYER JUST STOPPED HEATING UP WHAT CAN I DO TO REPAIR IT?
Replace the Heating Element. The heating element is usually located behind a panel on the back. To replace you will need to remove the back cover of the dryer, then locate the heating element. The heating element is screwed into place and is easy to unscrew and replace. Be sure to have the dryer unplugged while doing this.
Here is the part for it:
http://www.repairclinic.com/Kenmore-Dryer-Model-11060602990-ID-501912-Heating-Element-Parts
Mar 13, 2013 | Dryers
Hotpoint dryer model DLL2650BFLWH not heating
If this is an electric dryer, your heating coil has broken and is no longer conducting current and heating.
Oct 27, 2012 | Hotpoint TDL15 Electric Dryer
No heat
If this is a Whirpool model dryer (this includes Kenmore, Estate and Roper), the heating element will be located on the lower right hand side with the back panel removed. If the dryer does not have removable back panel, the heating element will be located inside the dryer under the drum on the right hand side.
Since you posted no brand name or model number, I'm going by the heading you posted this under. If your dryer model is different, please post back with your correct information so that I may assist you better.
If you have questions, please let me know. I hope this answers your question.
Jul 03, 2009 | Whirlpool LER5636P Electric Dryer
Dryer heating element
usually if it heats up but long dry times ,,air flow problem inspect exhaust hose and vent s should resolve problems...
Dec 27, 2008 | Kenmore 62602 Electric Dryer
NEED More info ...Need model # and type dryer... info u gave is misleading
Oct 09, 2007 | Kenmore 63942 Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
