FAN NOT RUNNING, WHERE IS PANEL TO GET TO FAN? HOW TO TEST FAN??
  • 162 Answers
Depends on what type of air conditioner it is
Posted on Jul 29, 2009
When i push the power on the fans start running and immediately turn off. power is on
1) normally the pc has software diagnostic installed by the company.
RUN the software diagnostic.
2) otherwise you must open the computer and test a) voltage a the FAN coming from power supply b)if there voltage at the FAN is faulty, if NOT the problem will be in the power supply section.
God bless you
Oct 02, 2012 | Fujitsu Siemens SCENIC E600 PC Desktop
My hp laptop fan not working
There is really no need to do a test. If you turn the laptop on and you do not hear the fan running it is bad. If you let the laptop run for a while it will shut down because it will overheat without the fan running. You will have to take the laptop apart to get to the fan that sits on the motherboard.
Mar 24, 2012 | Compaq Presario CQ56110US Laptop
Not cooling at all. Just cleaned filthy coils, but don't hear the evaporator fan running at all
The fan needs to be replaced.----------- Fans not running will cause the fresh food and the freezer sections not to work. If the condenser fan (the one under refrigerator) is not working, the compressor will cut off on the overload. If the evaporator fan is not running, there will be no airflow to the freezer or the refrigerator. First walk up to the refrigerator and listen to see if the fans (one in the freezer on one under the bottom) are running. If one is running and the other is not then get to the one that is not running and see if something is blocking it. If there is nothing blocking it then replace it. (Note that some refrigerators cut off the fan inside the freezer when you open the door so be sure that the door switch is depressed when performing this test). -------- If your fan stopped running and you replaced it and still not running, your going to need the main control board located on the back of the unit behind an access panel.
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Aug 19, 2011 | Frigidaire PLHS267ZA Side by Side...
The engine is over heating when the air condtion ing is on- the fans are not working.
  • You have a relay box under the hood back by the firewall on the passenger side. What happens is that fan relay goes out and the fan won't come on. When your AC is running the compressor is running and this makes your engine run much hotter than without the AC running. The fan should be on when ever the AC is on by default.
  • So under the hood (diagram #2) is the relay panel. When you lift up the lid to the relay panel there is a diagram of all the relays and fusible links inside there. Find the relay for the fans and this should fix your problem.
  • Thanks for using FixYa
Tony
Jun 22, 2011 | 2008 Infiniti QX56
The fan in the refrigerator isnt running and the milk is kind of warm? doesnt seem like the fan is working.
You may need to replace the fan, It's common for them to burn out, Just remove the back panel and unsnap the wire harness, you can test the leads for current there, If the power is there you just need to replace the fan.
May 22, 2011 | Refrigerators
I have a GE PROFILE pds22mhr and the freezer seems to be getting warmer. I took the back panel off and places some house fans on the coils and it seems to be dropping in Temp. I think the fan is no good...
Listen in the freezer side for the fan if you cannot hear or feel the air or fan running you probably need to replace it. Remove the back panel in the freezer to access the fan motor.<br /> <br /> <span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">If this was helpful please rate me.<br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas<br /><a href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a> </span>
Aug 31, 2010 | GE Profile PDS22MHR Bottom Freezer...
Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Jul 07, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
No lit LED, No panel control. Vent fan, running
We regularly repair these control panels for customers nationwide with our guaranteed $39.95 service.
Full details of our service are at http://www.microwavedisplay.com.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Aug 14, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE Side by Side Not cooling/freezing
sounds like defrost problem. remove back lower panel in freezer. defrost all ice on coils, this will fix problem temporaily. I`m looking for the tech sheet to test system.
Jul 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
