Question about Motorola Mobility RAZR V3
Vibration My phone will vibrate and not turn on.
    Brigadier General:
  • 7,752 Answers
Re: Vibration
You may need to have the phone replace or master clear the phone or reflash the firmware on can try one of those options....or explain further the problem you are having.
Posted on Dec 22, 2007
0 characters
3 Points
How to removed or turn off the vibration on the phone?
What phone you have would be useful to know but for
Android : How to Turn off Sound and Vibration in Androids Keyboard
Iphone: If you set the iPhone to vibrate in silent mode, it still makes an audible buzzing sound that may bother or disrupt others. If you need your iPhone to stay completely quiet, temporarily disable vibration. You can turn off vibration when silent mode is on, off or both. Tap the button next to "Vibrate on Ring."
Turning vibration on my mobile phone on or off
  1. Find "Notifications" Slide your finger down the display starting from the top edge of your mobile phone. ...
  2. Turn vibration on or off. Tap the indicator next to Vibrate to turn the function on or off.
  3. Exit.
Nov 09, 2015 | Cell Phones
Samsung u700 mobile phone vibration mode is not working
go to menu , then select settings ,then go to factory default setting,then it will reset,turn off for one minute then turn on again,then go to vibration setting ,then test if vibrating.if not the dynamo of vibration is defected a factory defects,just try this option...
Jul 04, 2008 | Samsung Cell Phones
Vodafone smart tab vibration mode
1. Find "Sound"
Press the menu icon.
Press Settings.
Press Sound.
Press Vibrate and ring to turn vibration on or off.
When the box next to the menu item is ticked (V), vibration is turned on.
3. Exit
Press the home icon to return to standby mode.
Dec 08, 2014 | Cell Phones
Could you tell me how to turn off keypad tones when texting on a samsung Tocco
Adjust the volume of the key tones
In Idle mode, press [up /down] and adjust the key tone
Adjust the vibration intensity on the
touch screen
You can adjust the intensity of the vibration when you
tap the phone screen.
1. In Idle mode, press [up /down].
2. Select Vibration and adjust the intensity of the
Jan 13, 2011 | Samsung Tocco F480 - Pay Monthly Cellular...
How to stop Vibration at sciphone i9+++ mobile . please help
pls clarify more ... but i think that is a similar problem. proceed to phone settings and set off the vibration. or changed your message/ringing tone to BEEP ONE . the vibration will come out once
Sep 03, 2009 | Dual Electronics CECT P168 Cellular Phone
Vibration Intensity?
Most cell phones don't allow you to control the intensity of the vibration... you can only turn it on or off. However, if you get a rubber case for the phone that might help, because it will absorb some of the vibration.
May 27, 2009 | Samsung Propel A767 Cell Phone
Turn off vibration
go to your ring option then deactivated the vibration
Dec 28, 2008 | Cell Phones
SMS alert not working
Check the ff:
-You might have turned your "message alert" off or your phones "volume" off or silent.
-"Vibration" alert is off
Try this:
-Turn the "vibration" on or activate.
-Be sure the phone "volume" is not zero, empty or off.
Notify me if it doesn't work, if it did pls rate this solution...tnx
Sep 27, 2008 | Nokia N73 Cellular Phone
My cell phone always vibrates
u edit ur profile and disable vibration first it wil automatically change ....
eg: u selecting meeting profile means u can edit that profile and turn off the vibration
May 20, 2008 | Nokia 6288 Cellular Phone
Motorola Mobility RAZR V3 Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
