Question about Black & Decker Drills
My 14 v batteries are not charging? - Black & Decker Drills
  • 2,176 Answers
What is the brand? How old are the batteries and is the charger working? Give me some more information and I will try and help
Posted on Aug 05, 2009
Yamaha 450 Kodiak battery not charging, new battery, volt meter not showing any voltage going to the battery
Hi Brian, get a digital volt meter and start the ATV measure the voltage at the battery or at the alternator it should read around 14 volts when charging, if it reads 12 volts the charging system is not working, check or a blown fuse or broken wire, if you can access the alternator directly measure at that point. It takes 14 volt output from the alternator to charge a 12 volt battery
May 06, 2017 | Yamaha 2005 Kodiak 450 Auto 4x4
HOW DO YOU CHANGE THE BATTERYS
Depends on what battery. car battery I charge with i 10 means with a current 1 / 10 of the capacity in Ampere hours for 14 hours. So a 80 Ah battery with 8 A for 14 hours.
A camera battery in the charger I got with the camera. Or a good universal charger from GP. A NiMH AA or AAA battery, with a quick charger that at least needs 2 hours to charge. The quick chargers I have that can charge in less than 2 hours (one can manage in 15 minutes) all kill batteries after a few charge cycles. Hope this helps.
Mar 15, 2015 | Cameras
Battery is not charging
So you have 14 volts coming from the alternator? Do you get 14 volts testing the battery posts? In other words are the terminals making a good connection and the wires are in good condition?
Feb 22, 2015 | Cars & Trucks
2006 Buick lucerne; while driving "service battery
Test the alternator out put.. First check battery for voltage.. should be 12v or slightly better.. Start engine and check the battery again.. and it now should be 14= VOLTS.. IIF ITS NOT 14+THE ALTERNATOR IS POSSIBLY BAD.
Sep 06, 2014 | Cars & Trucks
Battery discharges in about 3 days if not run.
it may have deffective diode on the charging system(the alternator). 14 volts is an over charge in a battery. ampere reading must be on what the battery designed.
Mar 01, 2012 | 1997 Jeep Grand Cherokee
Driving down the highway turn lights on battery power drains (check guages light comes on) turn lights off battery continues ot charge and hold a charge. . generator? Alternator?
first of all, check voltage at battery car off should read at least 12.5 to 13 volts. now start car. at battery it should read at least 14 volts, if lower then 14 volts check alternator.
Dec 17, 2010 | 1998 Dodge Ram 1500 4WD
The battery light is on, check charging system communication is displayed. Have changed battery with no change.
it may be the alternator thats not charging or its a over charge. at battery with engine off should read at least 12.8 to 13 volts, when engine is running, at battery voltage should be at least 14 to 14.2. if running and not producing about 14 volts. the alternator is bad, or the belt is slipping. check alternator voltage. have a good day !!
Dec 03, 2010 | 2004 Ford Expedition
Jazzy select 14 won't charged - have replaced batteries
At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity it says it fully charged but will die quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential resulting in short battery life. Also the new batteries need to be charged before they are put on your jazzy. Then its a matter of if not in use put on charge. I think you need to have a word with your dealer.
Oct 06, 2009 | Pride Mobility Products Jazzy Select 14
Drills Logo
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
