Question about Motorola Mobility V365 Cellular Phone
Trying to format micro memory card, does not take
On v365 I have inserted micro mermory card, when I try to switch storage devices to the card I follow the on screen instruction and "formatting failed".
Any suggestion how to get this to work?
  • 283 Answers
According to Motorola 512 mb cards are the largest you can use in this phone without problems
Posted on Sep 13, 2009
  • 922 Answers
The card might be damaged.
Try to read it and format it in a computer or another phone.
If that doesn't work the card is toast, sorry.
I hope this helps.
Posted on Jul 29, 2009
I have black jack..and wen ever i insert my 1gb micro sd,,it shows storage card not found,,,,so,can you just tel me the way to solve this issue....
Dear,
try inserting a different micro sd card of 1gb in your mobile, if it gets work, then you could be sure that their is a fault in your that memory card which shows storage device not found.
it may got currupt.
or try formatting that memory card through a computer, then insert it..
it may will work, but if not then its time to buy a new memory card as that card is currupt.
regards!
Aug 18, 2011 | Samsung Blackjack SGH-I607 Smartphone
2gb micro 2 mermory card is crupt so please solve this problem. Thank you yasir
SaveMyUsb.com can recover data from most damaged and faulty flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 30, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
I hve an samsung j700i. I am not able to delete anything from the memory card nor able to formatt it. It is an sandisk 2gb memory card. I have tried to formatt it on another cell but no use. i have tried...
Try formatting your memory card by inserting it in Micro SD adapter then insert this in the memory card reader and then try formatting it using HP USB disk storage format tool. This would probably fix this...
Sep 15, 2010 | Samsung J700 Cellular Phone
I have a LG Cu920 model and bought a micro sd 8GB card and used the USB data cable to connect to the PC and i am unable to get connection established as it displays connecting to mass storage device and...
When it displays insert memory card for connecting as mass storage device, switch off the phone and reconnect so the phone will perform as a memory storage device.
Good luck.
Mar 16, 2010 | LG Vu CU920 Cellular Phone
Cannot get my v635 to format memory card
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Jan 17, 2010 | Motorola Mobility V365 Cellular Phone
Card error
If you get a message as "Memory Card Error" on your camera AND you still need some of the photos , the first step is to format the card through the camera menu (Note: if you have an sD card, once you re-format your card any photos cannot be recovered.). check your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
To format* a memory card:
(*instructions on formatting memory cards can be found in your camera's user manual) you equally format the card using your computer if the above method fails,if the micro sd card is inserted into the sd slot of your system the computer sees it as a storage device in that way you can format it the usual way you can format a drive on your system but mind you if you have valuable pictures on it ,they will be lost but in that case you can use the low level format utility
Jan 06, 2010 | Olympus SP-700 Digital Camera
Storage card formated but it still does not show up. please help
xda orbit can only hold 2gb sd memory stick and doesnt recognise the HD-micro-sd.
or..
try formating it in a PC or laptop.
Dec 11, 2009 | O2 Xda Orbit Smartphone
I have a m2 4gb mermory card and i am trying to
you mean nfts code, fat 32? choose ntfs format, its better
Oct 19, 2009 | SanDisk 4GB Memory Stick Micro M2 Memory...
"Storage Device Unreadable. Format Now.?"
yes there is a possible solution to your problem....there seems to be a problem with your card....and it doesn`t look like you can get your data back from it ...so you will have to format your memory card....connect your card to a computer through a memory card reader by also using your micro card`s adaptor and then format it from your computer......hope this helps.....please vote ...help us to help you better
Aug 07, 2009 | Motorola Mobility V360 Cellular Phone
Problems with formating samsung e250 micro sd card
Did you try to format the card in the device thru Windows Media Player, or Rhapsody? If so, try formatting it thru My Computer instead. My Computer>Device Name>Right Click and select format. It is most likely NOT a virus if you have only put music on the device. It is most likely a corrupt file, or a database error. Best of Luck.
Sep 12, 2007 | Cell Phones
Motorola Mobility V365 Cellular Phone Logo
114 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
