Question about Magma DM10-016LP Grill
Lighting tempertaure knob just freely turns will not ignite, etc
  • 67 Answers
How old is it? Is it still in warranty Guarantee? If it is, take it back to where you bought it from and they should repair it or replace it. Disconnect the grill from the electricity supply. Open it up and see if the switch is turning? If it is tighten up the locking nut. If not, the swich may be broken and you may have to buy a new one.
Posted on Jul 29, 2009
Installed Dyna Glo BF30DTDG-1 NG Heater, pilot / gas knob won't turn-why?
Spay some wd40 on control knob some times they are still to move .
Dec 05, 2016 | Dyna-Glo Heating & Cooling
Rings make a clicking noise all the time they are ignited
Turn knob back from "lighting mode" back to normal flame level. If this is not the answer, there may be a control or wiring problem.
The clicking is the normal ignition spark system but usually only operates at the time of turn on until flame is on.
Apr 27, 2015 | Cooktops
How to relight pilot on boiler
Every boiler will have manufacturer lighting instructions on the unit, so be sure to read it thoroughly and turn off the gas for 5 min to make sure there is no gas build-up around the boiler. Some have electronic ignition and some require a manual lighting of the pilot. If the control knob has only ON-OFF, it has electronic ignition. Simply turn off the power (at the electric switch on the boiler or at the breaker box) and then turn it back on and it will relight itself when heat is needed) If it has ON-OFF-PILOT, you will have to light it manually. You will have to turn the gas valve knob so the arrow is pointing at the word "pilot" and depress the knob, while lighting the pilot with a lighter or match. Continue to hold the knob down after the pilot is lit for about 30-45 seconds to allow the thermocouple to heat up. If you release the pilot knob and the pilot stays lit, you can turn the knob to the "ON" position and the burner will light. Please be careful. if you are not sure what you are doing, call a professional.
Mar 01, 2015 | Heating & Cooling
I have a Valor Eminence Gas Fire which does not ignite when i try to put it on. Pilot light seems to be going but no gas. Can anyone help? I habe dusted the interior as per instructions but to no succes....
Be sure that after lighting the Pilot, that you turn the gas control knob to ON. Just lighting the pilot will not turn the burners ON. Once the control knob is turned to ON, you can turn the burners ON.
Hope this helped you and thanks for choosing FixYa.
Sep 16, 2011 | Heating & Cooling
When I go to start my grill, I turn on the gas and then the knob on the right side to spark the gas for the fire. When I turn the knob it does not spark the gas. Hoe do I troubleshoot what is wrong....
It sounds like you have a rotary piezo igniter, which means you get one click, or spark, per rotation. If there is no click when you turn the knob, or the knob spins freely when you turn it, it has probably broken. If you pull the knob of, there should be two screws behind the knob that holds the igniter to the front panel. Hopefully you can remove the screws and reach behind the panel to remove the igniter. If this wont work, you have to remove the front panel. If the igniter is not broken, then check the wires and electrode for shorts.
Jul 03, 2011 | Ducane 1005A (LP) Grill
Have a conti Euro 90 gas heater and lost the details for controls (lighting etc). Where can I find a site showing how to ignite etc?
Did you get a manual. I got a second hand heater and do not knowhow to get it started, I press the big knob, press the ignitor but the moment I leave the big knob the flame goes out.
May 27, 2011 | Heating & Cooling
The igition seems to be frozen. The battery is good as all the lights, buzzers etc are working. You put the key in the ignition and it won't turn. I've tried moving the steering wheel, made sure the...
It's possible. The parts store sells a small aerosol of deicer made for key holes. I would try this sparingly as there are electrical pieces in there. Good luck
Randy
Jan 21, 2011 | 2004 Suzuki Verona
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Ge gas range about 7 years old delay in lighting
take burner cap off and clean all the gas ports with paper clip etc.it sounds like the gas is not reaching the spark.usually clogged with grease or soap.hope this helps .please rate my answer :)
Dec 08, 2009 | GE Cooktops
The three burners on the top of the range will not light.
You either have an issue with gas flow from the control valves or with the piezoelectric gas igniters. Turn the knob to low and try lighting the burners by hand. If they work, then your problem is not gas flow but the ignition. Turn the knobs to light and see if each burner clicks and you see sparks at the igniters. If you are not seeing a spark, try cleaning up the igniter tips. If that doesn't do it, it is probably time to call the service technician (or the Hotpoint Customer Service hotline).
Mar 03, 2009 | Hotpoint RGB745 Gas Kitchen Range
Magma DM10-016LP Grill Logo
35 people viewed this question
Top Magma Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Magma Grilling Expert? Answer questions, earn points and help others
