No, it's not normal for them to be soaking wet at the end of the cycle, but there are things that can affect this. First, make sure you have Heated Dry selected. Next, make sure you are using rinse-aid (Jet Dry), because the new dishwashers don't use as much heat as the older dishwashers, and Jet Dry will greatly aid in the drying. Be aware that plastics won't get dry in any dishwasher. Other things you can do is turn on the extra heat options in the wash cycle, and turn on the Sani-Rinse option (if you DW has such options). Otherwise, you may have a heater or controller problem.
I would soak as much of it up as I could with sponges and dishrags, towels, whatever works. When you run it, just make sure it's not leaking bubbles all over the kitchen...run it and turn it off to let the bubbles subside...back and forth until you can run a cycle without too much bubbly residue.
It won't hurt it, just can be a scary blob of bubbles!
Good luck, and hope this helps.
HI- Ah yes, the suds. Your flood switch has probably been tripped. Unplug the machine or flip the breaker. Remove the lower kick panel and you'll see the white plastic bottom of the dishwasher pan. This is designed to catch the water (or suds) if there is a leak or the water (or suds) over fill it. This will take awhile but get some pliable rag and carefully put it in the space between the bottom of the dishwasher and the pan. There is a styrofoam float on the left side about halfway back, this has to be down for the dishwasher to advance the cycle and get out of drain mode. Just keep soaking the water up (you kinda have to go over the plastic lip of the pan and down wherever there is an opening large enough to get the rag into. Once it is pretty dry it should run ok.
Regarding the suds. If you get the machine to run ok then start a rinse cycle and once the water is done filling open the door and add about 4 tablespoons of any cooking oil to the water. Shut the door and let the machine run for about 10 seconds, open the door check to see if there are still a lot of suds, if so cancel the cycle to drain the machine and repeat. Hope this helps, good luck.
Yes this means that the machine is detecting water under the bottom drawer. Pull the bottom drawer out and soak up the water with a towel and then the error will go away. This happens often because something gets put in the drawer that's too tall and doesn't allow the lid to come down all the way and seal.
