Question about RCA P52926 52" Rear Projection Television
Rca p56926 convergence problem
I have a RCA p56926 projection TV
I turned it on the other day and they colors are all messed up. It has the concave effect at top and bottom, looks like its a cheesy 80's 3d movie. Can anyone tell me how to get to the crosshairs screen to try and adjust this. No where does it have this option. I found a site saying to try to hold the menu button and press power then vol ^. This brought me to another screen with P0 and V0 but then nothing. Any help would be appreciated
Thanks!
  • Anonymous Nov 23, 2007
    I have the exact problem with my 52" projection tv. I'm just going to have a tech repair the covergence circuit board because I don't want to mess with something that needs to be soldering.
  • kraze3 Dec 03, 2007
    any idea where I could find the replacement? Is it a soldering project or an easy fix?
What was the solution to find convergance screen?
Posted on May 27, 2010
    Problem Solver:
  • 11 Answers
I have a 56 inch RCA Television , with the same exact problem
the tv is now about 12 years old and has been fixed twice for this problem.
RCA is aware of this problem and i fail to understand why they would continue to manufacture a product that is defective and could be unsafe.
you need a tech to look at it . soldering is fix or new board ,
i had two "L" brackets installed to keep the " plug in" board stable .. seemed to be the root of problem. these tv's don't like to be moved.
the tv is serviced by Thompson products U.S.A.
mine broke down right away. and even after three years and a second time . i complained to rca that for three grand i paid for tv ... it better work more than three years or they would be recieving a rather large paper wieght on the front door step.
Posted on Dec 16, 2007
    Genius:
  • 1,694 Answers
Kraze3,
Your set has a repair issue with the convergence circuit.
Adjustments in the service menu will not help.............I agree
with Guest comment.... circuit board repair or replacement is
what you both need.....................T.
Posted on Dec 03, 2007
  • Vista Electronics Dec 04, 2007
    kraze3,
    Convergence circuit board part # is 250586 = about 100.00 or
    more = may or may not fix your problem = have local RCA tech
    look it over.........T.
Rca p56926 screen is concave and cant adjust convergence in menu
Convergence can only be repaired by going into the unit itself....You MUST know how to do this or risk a lot more problems.....seek qualified assistance!
Aug 29, 2009 | RCA P52926 52" Rear Projection Television
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA 52 in HDTV red, green and blue colors not alligned - concave
That repair only repairs the issue of the convergence option missing from the on screen menu. If thats what your problem is then the ITC222A convergence option missing repair kit at the following link should repair the issue. The kit contains the fl231, DL231, CL230 and the CD with detailed instructions.
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA D52W19 52" Rear Projection Television
I have an RCA 52inch rear projection tv model No#R52wh74 when i turned on the set the screen went into some concave mode and the color is al distorted what do i need to fix this
DO you have convergence in the customer setup menu? if you do not then check out the article fl231 problem in the tips and tricks section
Apr 28, 2009 | RCA R52WH73 Projection Television
Posted by RSDHDTV on Dec 16, 2008 My RCA has a Concave 3D look to the picture and the red blue and green colors are out of convergence
YOU HAVE A CONVERGENCE PROBLEM. THE CONVERGENCE IC'S NEED TO BE REPLACED AND POSSIBLE RESISTORS AND IC PROTECTORS. EST $300- $400. IF TAKEN INTO A SHOP.
Jan 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P56926 Would not turn off
This tv make a lot loose connections. If you re solder and nothing change, check fly back area's is OK?... Look around convergence board for liquid coolant ( some times CTR liquid coolant projection splitter , becarfull, Liquid is danger!!) Wash yous hands and clean chassis with acetone.
Apr 19, 2008 | RCA P52926 52" Rear Projection Television
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
52 rca concave pic and bad colors
concave and colors off indicate the convergence cuircit is bad. which can be one of three boards. sorry
Dec 08, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA P52926 52" Rear Projection Television Logo
373 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
