Question about Cuisinart DCC-1200 Coffee Maker
Coffee leaks all over the counter every time coffee is made. coffee appears to be coming out of bottom of machine Coffee pot lid is on correctly.
I had this problem after about a year of use. The thermal carafe lid had become clogged enough with coffee sludge (fine grounds/oil) and hard water deposits to slow the flow through the lid. I soaked the lid in a bowl of 2 cups hot soapy water + 2/3 cup white vinegar for a few hours, agitating the lid in the mixture every 1/2 hour or so.
Then, I rinsed the lid and packed baking soda in every opening and dropped it back into the mixture - hoping the fizzing action of the baking soda+vinegar would help loosen any remaining sludge.
I rinsed it again, and whacked it against the side of the sink for a final effort to loosen sludge. Repeated the baking soda + rinse + whacking a couple of times. No more problems.
In the future, I plan to do the soak at every Cleaning cycle/every couple of months.
Or, if you don't want to deal with it, replacement thermal carafe lids are available from Cuisinart for $6 + shipping.
Posted on Jan 11, 2010
  • xxxx Jan 02, 2012
    Thanks- it worked out well for me.
  • 8,596 Answers
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Posted on Sep 29, 2009
I had my 1st Cuisinart and we moved so the coffeemaker was in storage for 6 months. It leaked after that. Now I have the 2nd Cuisinart. The problem is in the manufacturing of the machine. They used a cheap solution to clamp the tubing under the machine. They used wire instead of a clamp. This is cheap workmanship. I could not get another tuble. I made Cuisinart aware of the problem.
Another reason that your machine might leak is that the lid gets clogged with coffee and needs to be cleaned periodically. You would see the coffee spilling out.
Posted on Oct 06, 2009
After many months of this recurring problem, we found that a courser grind of coffee kept the liquid from backing up and leaking.
Posted on Feb 07, 2013
DCC-1200 leaks coffee onto carafe and warmer plate
My coffee pot was leaking over the carafe and onto the warmer. I found that this issue was caused by the carafe lid. The lid was not allowing coffee to flow into the pot fast enough. I removed the inner mechanism from the carafe lid (it pops off really easily) and just sit the lid on top of the pot while brewing, and no more leaks! After brewing, I put the mechanism back onto the lid and twist lid onto the pot.
Nov 16, 2012 | Cuisinart DCC-1200 Coffee Maker
DCC 2400 COFFEMAKER LEAKS CONSTANTLY. ALL OVER THE COUNTER. HAVE CLEANED IT. IS IT FIXABLE SHOULD I TRASH IT?
I had this problem.
The Fix:
There is a valve in the centre of the carafe lid (If you shake the lid you can hear the valve rattle). This valve becomes gummed up with heavy coffee oils over time and sticks causing part of your brew to pour onto your counter. The fix is to simply clean the oil out of this valve. I cleaned mine by soaking it overnight in a water/bleach solution then blasting hot water into it. You can clean it more thoroughly if you pop off the bottom lid part that extends into the pot. It is a snap fit. Before you take it off note the orientation.
On my lid this valve was coated in heavy, greasy coffee oils. After this cleaning your pot should not leak when brewing.
Another problem is the stiffness of the lid making it sometimes very difficult to open and close and if not fully closed coffee will leak while pouring. This o-ring binds against the carafe. To fix this, locate the 'O' ring in that same part the extends into the carafe on the bottom of the lid. put a drop or two of vegetable oil on your finger and apply a thin film around this ring once every three weeks or so. Your lid will open and close smoothly and beautifully.
Happy brewing!
Feb 22, 2011 | Cuisinart Brew Central 12-cup Coffee Maker
I love my Cuisinart 10 cup coffee maker, but I hate my pot. Every time I pour a cup of coffee the pot leaks. I have tried removing the lid and the pot still leaks. Please help I am getting tired of...
Be careful! The top will soon disconnect from the bottom! I've had the same problem for the last few months. This morning (11/19/10) the top of the pot seperated when I poured a cup of coffee and half a pot of piping hot coffee spilled down my right leg. I'm on hold with their customer service department as I type this. Has anybody else had the same issue?
Regards,
Harry B.
Nov 11, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
MACHINE LEAKS WATER
Turn on machine w/o water or google the company
Jun 02, 2017 | Waring Pro WC1000 Coffee Maker
The plastic top of the glass pot on two coffee makers drip.
This is a design flaw and can be corrected by enlarging the lid spout. First remove the plastic lid. Then use a fine grinder or sandpaper to remove approximately 1/8 inch of plastic from the lid spout. Follow the exact same contour of the oval spout. However, do not take off so much material that you disturb the small plastic tabs that hold the lid to the pot. Finish by slightly rounding the edges where the material was removed with fine sandpaper. No leaks - no drips.
Apr 26, 2009 | Cuisinart DCC-1200 Coffee Maker
I am having a problem with my Starbucks Barista Aroma Grande Coffee maker We have had it for 5 years and it has been great but recently almost every time I make coffee and walk away from it, I end up...
The exact same lid is on the Wolfgang Puck WPTPCM010 coffee maker. (It's exactly like the Starbucks one - same size & fit.) Call (800) 275-8273 and order part # WPTPCM010-6; the product description is "LID FOR CARAFE". It will cost you $4.99 + 5.00 shipping. My Starbucks coffee pot works PERFECTLY again. Just make sure that you put the lid on the carafe correctly before you use it, since the seal is new.
Mar 06, 2009 | Starbucks Barista Quattro Coffee Maker
Leaks at bottom
look for leaks up at the top by the top hinge.
mine leaks there. apparently a gasket is missing or just not tight enough.
you should see bubbles come out and see water go into the filter cone but some of it leaks down the inside (near the pot inside) and out the bottom of the maker and appears to be leakng from the bottorm.
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
3,175 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
