Question about Yes Audio Players & Recorders
Jam Heavy Metal P920 powers on, says its paired, about 3 seconds says powering off. What has happened. Yes it has a charge. Help !
I love my Jam,, I really want it to work again. I miss listening to one small but very powerful and best sounding speakers out there !
SOURCE:
  • 8 Answers
SOURCE: Nokia 6300 wont power on
check on that battery connector isnt damaged it looks like you middle pad BSI line its not connected properly
Posted on Feb 18, 2008
SOURCE: Protect and Push power
A sign flashed across the screen "Protect and "Push power" Please what does this mean? and what do i need to do to fix it?
Regards
Fabio Catarcione
Posted on Nov 25, 2008
SOURCE: Creative Inspire T6100 5.1 - No Power
are you sure if you plugged into the right spot
Posted on Dec 14, 2008
cuvilldj
  • 14 Answers
SOURCE: INFINITY AMP PROTECTION LIGHT FLASHING
Overload maybe. If the amp is run at an improper impedence, the amp will shut down. If you are "CLIPPING" speakers / subwoofers the light will blink to indicate a hard clip . Example: 4ohm/2ohm stable amp with 4 ohm subs wired at 1 ohm.
Posted on Jan 29, 2009
HitWizard
  • 67 Answers
SOURCE: INFINITY AMP PROTECTION LIGHT FLASHING FOR 5 SECONDS
I have an Infinity amp as well, and I was having the same issue for a time. The amp is protecting itself from some sort of overload. It could be the Ohms load on the sub, but I would guess not. Make sure your low pass filter is set to LP and not HP or Flat. Then check the RMS on your subs and match that to the Amp RMS. Once I did all that I found that everything worked fine, for a time. It started doing this again, and I checked the fuse and it was blown badly. It seems that the fuse setup on some of these Infinity amps is not as good as one would hope, because the charge was bridging the gap and frying out my fuses. It was like a spark would jump from one side of the fuse to the other without travelling the fuse itself, and this was causing my protect issues. I pulled the fuse, got a new one of the same rating, but I placed the fuse in with a little piece of rubber in between the 2 contacts, and then connected to the fuse block. I have not had problems since.
Posted on Feb 02, 2009
Jambox
The same thing it's happened when my jam box won't turn off because the Power Button has sunken in!? Someone help!
Aug 28, 2014 | Jawbone Big Jambox Portable Bluetooth...
Hey I have an hdmx jam xt extreme wireless Bluetooth speaker & after a few seconds after I have paired with mine or a friends phone the music will stop playing, this sometimes doesn't happen if the volume...
To me it looks as if the battery is not charged ok. I'm not sure if you can monitor the battery voltage, but if you could, and you saw the voltage drop bellow a certain voltage and the speaker stopped there, and you could repeat this that would be the case. But perhaps you just charge the battery and discharge it a few times, before you panic. Some batteries only start working with full power after a few charges.
Jun 23, 2014 | Radio Communications
HP Pavilion DV7 freezing during charging
When your laptop goes on battery power the processor automatically gears down to conserve battery power, but when charger is used the processor goes to full power and you run heavy programs drawing more resources, I suggest you upgrade your ram because heavy gaming uses more ram memory.
Jul 04, 2012 | Computers & Internet
I have charged my pro+ but it wont power on i have no red or blue lights only red when charging
hold the power button down for about 3 seconds- that should either 1. put it into pair mode (red + blue), or 2. Shut it down so you can retry pairing/turning them on.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Jun 22, 2011 | Plantronics Voyager PRO Bluetooth Headset
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Does the above have a fuse inside the case / AC power supply? PC has suddenly developed a start up problem - power on light flashes once for a split second then power (appears to) cut off. Any idea(s) as...
yes you will find 2 or 3 fuses inside the power supply, see and smell for some burnt parts, like trancistors it will be 3 or 5 legged device with a metal back.
if some thing is burnt do not replace fuse the power supply needs to replaced.
beware replace fuse only if no parts are burnt, do not test in open state to avoid electrical shock.
Dec 23, 2010 | Sony VAIO PCV-W30 PC Desktop
We had to order a new headset (ear piece) to our CS70 system. Do we need to program it? It is not picking up the handset.
To pair another headset to the same base, you must first enable the multi-shift
pairing feature. Long press (5 sec.) the speaking volume minor adjust up button on
back of base until the power indicator light flashes.
2. Place a charged headset in charging cradle and red indicator light on base will flash
for 2 seconds if the multi-shift pairing feature is enabled. Within 10 seconds of
doing so, press either the "+" or "-" listening volume button for 3 seconds until the
headset talk indicator lights to indicate pairing mode, and goes out after successful
pairing. Repeat steps
Jul 11, 2010 | Plantronics CS70 Wireless Headset
MY PRINTER WON'T PRINT ERROR CODE 0XC05D1281
First, be certain there are no tiny pieces of paper in your printer, left from the paper jam.
Then, you need to reset your printer - try:
1. Unplug from the power cord.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power check the functionality.
And, if the above doesn't fix:
1. Unplug the power cord from the back.
2. Wait for the unit to go to the sleep mode. Wait for 60 seconds.
3. Press and hold Print Photos & Photo Fix
buttons simultaneously on the control panel; keep them pressed and reconnect the power cord.
4. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
Good luck.
Jul 04, 2009 | HP Photosmart C8180 InkJet Printer
Bluetooth headset
USING THE HEADSET
US USING THE HEADSET
1. Headset
2. Control Button
3. Light Indicator
4. Microphone
5. Earloop
6. Speaker
7. Charging Jack
A. Charging
Charge for at least 20 minutes before
first use. Complete charging in 2 hours.
Headset will not function when charging.
B. On/Off, Volume↑↓
Press the Control Button for 2 seconds
to power on. Press the Control Button
C. Pairing
Begin with Headset turned off.
Press button for 6 seconds. Release
button when Light Indicator flashes
blue/red. Headset is ready to pair with
Bluetooth device.
D. Pairing
Use your device’s menu to begin
pairing mode and select “320
Plantronics” on the display. When
asked for passkey, enter “0000.”
Jul 13, 2008 | Plantronics Explorer 320 Wireless Headset
23 people viewed this question
Top Yes Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Yes Audio Player and Recorder Expert? Answer questions, earn points and help others
