Question about Plumbing
Water is not pumping throughout fish filter pump
Why is the water not filtering throughout the pump? The pump filter is spotless clean, no water damage to electrical components and everything is connected correctly.
  • 32 Answers
And the pump runs right? There may not be ant water at the inlet side. You will need to **** the water to the pump, like a syfen.
Posted on Sep 03, 2009
2 Suggested Answers
  • 832 Answers
SOURCE: water is not pumping throughout pump
It means your pump was running dry. Running your pump dry normally damages the mechanical seal.
However, you may open and fill the priming port full
with water. Using the gate valve, set it at full close and
start the pump running. Then, open the gate valve two
full turns to stabilize the water flow. Send your e-mail
for further assistance. Thank you and God bless U.
Posted on Oct 27, 2009
What order do I put replacement filter media into the frf-1919 aquarium filter?
The goal for the filter would be to keep the water pump clean, so normally you would place the mechanical filter media where the water enters the filter. The water should not be able to go around it, but instead have to pass through the media. Mechanical filtration pulls out pieces of things. If you accidentally get too much food in the tank, and it makes it to the filter, this is what you want to pull out and clean at the faucet. Remove the debris, run some tank water through it so you remove the chlorine, then put it back in the filter.
Carbon/charcoal and sometimes white rocks called zeolite will be doing your chemical filtration, removing heavy metals, and other chemicals, so they can go next. The biological filter media is what is most important. Have this media - a large amount of surface area that water moves through, but will not get clogged up - next to the pump part of your filter. NEVER change these. These are the home for your beneficial bacterial cultures. Detritus (decaying organic material, solid waste, uneaten food, dead plant matter) and liquid fish waste become toxic ammonia. These bacteria consume the ammonia and turn it into toxic nitrites. Another bacterial culture living in the same place turn toxic nitrites into nitrates. Nitrates are plant food, here comes your algae if you leave your lights on all day but don't have live plants in your tank. Nitrates gradually build over time, and fish gradually become accustomed to higher levels of nitrates. This is why we do Regular Partial water changes, to keep nitrate levels low. If you don't do Regular Partial water changes, and suddenly change a lot of water, or add a new fish that doesn't get the long period of time to acclimate to these higher levels, fish can get sick and some may die.
Biological filtration is the most important thing in your aquarium, second only to water. Know where your bacteria live and DO NOT clean it, replace it, dry it out, bleach it, wash it under tap water, and so on. Just leave it alone the same way you leave your fish alone.
Fish can survive just fine without mechanical and chemical filtration, so there is really no need to continue to use those in your aquarium, other than keeping your money in the pockets of the people who tell you that you have to have them and you have to replace them. Any company that tells you the biological filter media must be replaced is lying to you and I would urge you to never buy their products again.
A bulk amount of carbon and nylon mesh bags can be purchased from any decent pet store or supplier, as can foam that can be cut to fit into your particular filter. Personally, I recommend not bothering with either of these, and adding more biological filter media in the extra space you now have. You can never have too much beneficial bacterial in your tank.
Sep 10, 2014 | Fish
Cloudy water that stinks
1st priory is to save the fish !! move them to a new container consisting of half old water and half new water (declorinated) along with a small air bubbler !! this should help your fish to recover (don't use soap to clean out container it is toxic to fish) moist table salt is best to use for a cleaning agent and rinse well b4 putting fish inside
then ck to see if your aquarium is pumping water thru the filter and falling back into tank ( replace all the water in the tank 1st with two rinses ) make needed repairs to pump and or filter assembly (New filter cartridge) new pump impellers and cartridges are available for purchase for your aquarium from vendors that sell aquariums and allways ck the outlet the pump is plugging in b4 blaming a pump fail with a known good table light set to "On" they do go off once and an a while
verify that water chemistry is ok b4 retuning fish to tank and observe fish for strange behavior for next several hours ( upside down swimming, laying sideways )
Jan 02, 2014 | Marineland Filtration Eclipse Seamless...
How do I clean the pump on a front loader Whirlpool washing machine, when the filter is spotless. (Red Pump clean light is on) Machine doesn't drain properly leaving clothes soaked.
If you have a top front small panel, unscrew 3 or 4 screw then you can pop out the cover. The pump is right there, you can counter clockwise the filter out and clean the pump. Be aware to do it with the power off.
If you don't see the front small panel, you have to open the back cover at the back of the unit.
Oct 13, 2013 | Whirlpool Washing Machines
How do I change the water pump in my aquarium?
There are a few simple steps to follow in order to changeyour aquarium's water pump:
  1. 1. Turn off all electrical componentsof your tank including lights, filters, vacuums etc.
  2. 2. Remove all of the fish andplace them in ample fresh water
  3. 3. Remove all of thecomponents of the pump (some internal and some external, depending on yourmodel)
  4. 4. Familiarize yourself withthe different parts of the water pump. Obviously, the exact installation process will vary from product toproduct
  5. 5. Lay out and attach all newtubing
  6. 6. Build the small pieces ofthe pump and insert them in place
  7. 7. Install the filters andsump (if relevant)
  8. 8. Plug in and turn on allelectrical components. Ensure thateverything is functioning before returning the fish to the aquarium
  9. 9. Return the fish to the aquarium
May 13, 2012 | Fish
What is the difference between a filter and a pump in a fish tank?
A filter maintains a natural environment that for fish thatbalances the good and bad bacteria in the tank. Additionally, a filter can remove toxins, chemicals and other unwantedmaterials from the water. The filterworks by taking water in from the tank and returning it clean.A pump is just a pump. It pumps air into the tank and creates bubbles, and sometimes a current. It does not clean the tank or balance thebacteria and PH like a filter does.
May 13, 2012 | Fish
I just noticed that my fish tank air pump broke. How long can the fish survive with a broken pump?
As long as you have an air filter, your fish will befine. Just like pumps, the air filtersmove air around and oxygenate the water. The air pump is superfluous. If you do decide to purchase another pump, please see thisvideo on how to install it properly:http://www.youtube.com/watch?v=gTnfXgmMTxY
May 13, 2012 | Fish
The pump is not sucking up the water into the filter.
filter must be full of water to start.check that pump is spinning.check that suction tube is submersed & not too long some fish tank filters have a knob on top of the elbow between suction tube and pump housing,turn it back & forth to control flow.give the suction tube a wiggle where it meets pump housing.
Sep 24, 2009 | Tetra Second Nature 8.4oz. Desafin
Water is not pumping throughout pump
Jul 29, 2009 | Plumbing
Plumbing Logo
74 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
