Is there a way to calibrate the oven temperature with the set temperature on a Frigidaire pro series.
SOURCE: OVEN WILL NOT COME UP TO TEMPERATURE
Yes there is something you can do. you can close the gap in temp by + or - 30degress by pressing and holding the bake button the display will change to 0 and now you can press up or down to what you want to calibrate it to. when set press start. now it's set. If your temp wonders off again you will have to replace the temp sensor. NOTE: SOME MODELS ARE DIFFERENT IN CHANGING THE CALIBRATION REFER TO THE OWNERS MANUAL IF THIS DOESN'T CHANGE YOUR CAL-SETTING
SOURCE: Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
SOURCE: I need to calibrate an electric oven
Probably. There is often a key sequence that will enable a calibration mode. We need the full model number to find the tech info, or you can probably find it in the tech sheet which is normally taped on behind the control panel.
