Question about RTO Atwood DSI-RV Water Heater-6 Gallon
Water heater working fine but very little hot water coming out
10 gal dsi atwood lots presue
  • 117 Answers
Alot of time those small units do not have a fast recovery rate so if they are on for a min or more they might start to lose temperature. if it's on demand especially in cooler climates it might not have enough power to heat it up and keep up with your demand
Posted on Aug 01, 2009
What Atwood water heater models will replace model GCH6A-9E?
Any 6 gal will fit in same cut-out (hole) . 12-5/8" H x 16-1/4" W x 17-5/8 deep. In order to move up to a 10 gal, you need to be able to cut hole a little bigger. 15-3/4" H x 16-1/4" W x 20-5/8" deep. Usually your depth will allow , and width is same, just a matter of whether you have room to make height bigger.
Jan 03, 2013 | RTO Atwood DSI-RV Water Heater-6 Gallon
Mt 6 gal. atwood hot water heater ignites but will not stop I put a new relief valve on it because it was leaking.
Excessive temperature from running too long will cause relief valve to open. If water temperature is too hot, thermostat & ECO should be changed. They are in behind that little foam cover where the letters are marked on cover. Check that they are up against tank good when you remove foam cover, as that may be the cause as well. They need to be held against tank, by the little coil spring and retainer. If they are against tank good, then replace them.
Dec 09, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Have a 2005 coach w/Atwood DSI-RV 6 gal water heater. Gas lights, heater fires and gets hot, but doesn't transfer the hot water through the lines to the sink faucets. jwmystery@aol.com
You need to check by-pass valve(s) on back of tank for proper position. You need cold open going in to bottom tank fitting, and hot open at top. If any valves in between those 2 lines via "T"'s, turn them to off position.
Oct 29, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a 6 gallon Atwood water heater, model GCH6-7E, DSI, heater lights off on gas when swithch is placed to on position. Heats water very hot , but when switch is put in off position, flame is reduced by...
Your on right track. When this happens and small flame still there, pull wire(s) off at gas valve, or test for voltage from ECO to gas valve. No voltage, then there should be no gas. Change gas valve.
Oct 20, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Warm water, not hot , Atwood 6 gal.- burner , propane -ok
can you turn it up ... ? Maybe the burner needs cleaned ... might have spider web in the burner ... blow out with compressed air or canned air ...
May 02, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwwod 10 gal gas/elec water heater won't work on elec.
THE LIGHTED SWITCH SHOULD BE THE 12V ENERGY SOURCE TO ACTIVATE THE LP SIDE OF THE HEATER. THERE SHOULDN'T BE A LIGHTED SWITCH FOR THE 110 SIDE. THERE SHOULD BE A SWITCH OR A COMBINATION OF SWITCHES. ONE ON THE WALL LIKE A LIGHT SWITCH AND ONE MOUNTED BEHIND THE HEATER.
Jul 07, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
224 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
