Black ink nozzle clogged, cannot print no matter how many times i run nozzle cleaning.
    Problem Solver:
  • 7 Answers
If it has ink in it, then remove the black cartrige and take a damp cloth with water and wipe the print head,( once you wipe it a few times, you should see black ink on the cloth)
Posted on Jul 29, 2009
Mg7120 won't print black on paper,but will print pictures with black just fine
It looks like you may have 2 black ink cartridges; one for black-and-white printing, and one for color printing. The larger one may have clogged nozzles. Run a cleaning cycle several times, and see if that solves it.
Other options which would be entirely at your own risk:
1. Dabbing the print nozzle head with warm water on a cotton swab.
2. As above with a mild solution of rubbing alcohol.
3. Soaking the print head overnight.
4. Applying vacuum to the print head.
Feb 11, 2017 | Black Office Equipment & Supplies
The black ink has stopped printing. Put in two different new cartridges and that doesn't seem to be the problem. It was first noticed when photos were printing out funny even after changing the color...
Make sure you are inserting genuine Lexmark cartridges.
Try to clean the cartridge nozzles. Refer to the steps below:
Cleaning the Print Cartridge Nozzles:
1. Open the Lexmark Solution Center. Click Start > Programs or All Programs > Lexmark 1300 Series. Select Solution Center.
2. From the Maintenance tab, click Clean to fix horizontal streaks.
3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
4. Print the document again to verify that print quality has improved.
Using the control panel
1. Press Menu.
2. Press the down arrow button until you highlight Clean Cartridge.
3. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Oct 13, 2011 | Lexmark P4350 All-In-One InkJet Printer
I have a canon multifunction MX700. Suddenly, my black ink stopped printing. Printer prints in other colors. I have turned the power to both printer and computer on and off, have checked the USB cable,...
Dear Adrienne,First make sure that the black ink is not empty. If you are sure the black ink is full enough you need to check the print head condition. The print head may be clogged or faulty.
To fix the clogged print head,please perform the following step:
  • Print the nozzle check pattern, access the following menu on LCD: Menu>Maintenance>Nozzle Check. The good nozzle pattern should like below sample image.
  • If the print head nozzle missing some color (i.e Black) the perform print head cleaning: Menu>Maintenance>Cleaning. Then print the nozzle check pattern again. Note: you may repeat this step up to 3 times.
  • If the problem still remain,then you should perform Deep Cleaning: Menu>Maintenance>Deep Cleaning.
If you have perform the above steps but the problem still the same,please check whether the black nozzle missing partially or totally. The faulty Purge Unit (ink pump) may cause the same problem. I mean the purge unit does not work properly so the ink cannot flow. Good luck :)
Regards,Xanda
Oct 05, 2011 | Office Equipment & Supplies
It won't print in black. We have tried 3 differant cartridges. At times it prints a shasding of the image. All the other colors work fine.
Use the HP Printing Assistant software to run a few "print-head-cleaning-cycles".
The BLACK ink-jets are CLOGGED. So, no ink from any of the 3 different cartridges reaches the paper.
Mar 15, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Will not print in black. will print in color. I
Sounds like a badly clogged nozzle. If you are using aftermarket/refilled cartridges, the changes are the ink is not up to manufacturer specs and has dried and clogged the nozzle. The best way to clear this is to take a new black ink OEM cartridge and run the deep cleaning a number of times (at least 3) to see if the nozzle can be cleared. If you continue to use non-OEM cartridges, I would keep a set of OEM cartridges around for nozzle clearing purposes. Also, take the aftermarket ink cartridges back to the vendor and either get an upgraded cartridge or refund.
Let me know if this corrects the problem. Thanks.
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Black ink jet doesn't print
if your black ink does not print, there is a possibility that the nozzle of your printer are clogged by dried inks, to print a nozzle check. turn off the printer then press and hold the paper (middle) and power buttons together for 3 seconds then release. it should feed the paper and print a nozzle check pattern. if the black lines are full of gaps or breaks in the line. you need to do head cleaning to remove the clogs, press and hold the ink button (teardrop) for 3 seconds, wait until the power (green )light stopped flashing. turn the printer off then print a nozzle check again. just repeat the head cleaning process until the black pattern is ok, as well as the other colors. all shld. be complete.
then print
Feb 11, 2010 | Epson Stylus Photo R200 InkJet Printer
Will print only color. will not print black with a
First print a test page to make sure the printer's firmware is working correctly. See here. Check here to see that you have the most current driver installed for your OS.
Then use this article to set the print properties to print in grayscale using the black ink cartridge only, and test the printing.
If you get no output from the black cartridge, see this article or this article for help with cleaning and checking the cartridge contacts. Make sure the tape is removed from the cartridge nozzle. You may try running the auto clean utility a couple of times, but be aware that this consumes ink, and if you are not getting black printout, it's likely that the print nozzles are clogged with old ink. Sometimes even a new cartridge can be out of date, or have been stored incorrectly, and cause this.
I've read of cases where people were able to use a vacuum nozzle to clear clogged cartridge nozzles and get them operating again, but haven't tried this myself, and recommend if you do you attempt it in an environment where ink can be cleaned up. (See here for more on that.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 28, 2009 | HP DeskJet 5150 InkJet Printer
Canon S900 - No black ink (none!)
Clean the contacts on the back of the print head.
Aug 22, 2009 | Canon S900 InkJet Printer
Changed the black ink and while it's seems like the document is printing, no ink appears on paper.
This was Rob's response to a similar problem which I had. d0c4ec0.jpg robmcd27
Rank:guru_s.gif Guru
Rating: 85%, 6 votes
The black ink is not the problem, it's the nozzle. The nozzle for the black ink head is clogged with dried up ink. If it were mine, I would remove the print head and use a q-tip dipped in alcholol to clean the nozzle. Let the alcohol dry and put it back together and run another auto print head cleaning.
You're probably going to have to do it a few times. It's going to depend on how bad the clog is. This will fix you...just be patient. Remember that ink has been dried on several months. Don't forget to rate my help. Thanks for coming to FixYa.com
Rob
Dec 21, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Black Horizontal lines
hi!
Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
    1. check if there is plain white paper in the Input tray.
    2. Press Setup .
    3. Press < or >to select Tools and then press OK .
    4. Press < or > to select Clean Print Cartridge and then press OK . The unit prints a test page.
    5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    5. Click the Estimated Ink Levels tab.
    6. Replace any ink cartridge that is low on ink.
  4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them
    4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
    5. Allow the cartridges to dry before reinserting them.
    6. Close the unit, and plug the power cord back in.
    7. Print a self-test page to check the results. Follow the steps below to print a self-test page.
      1. Press Setup .
      2. Press <or > until Print Report displays and then press OK .
      3. Press < or > until Self-Test Report displays and then press OK . The self-test report prints.
    8. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
- hope it will help to resolve you problem...
Jul 14, 2008 | HP OfficeJet 6210 All-In-One InkJet...
562 people viewed this question
k24674
jasbo
jasbo
