It stops playing at a specific location every time until you manually skips over it to continue playing.
Hi there.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. ... If theCD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.31 Mar 2015
How to Fix a CD Player That Skips ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-a-cd-player-that-skips
Why does a CD player skip?They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.12 Aug 2005Buyer beware: to fix a CD that skips, first try good old soap and water ...www.telegraph.co.uk/.../Buyer-beware-to-fix-a-CD-that-skips-first-try-good-old-soap-an...Search for: Why does a CD player skip?
How do you fix a CD player that skips?Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lenscleaner.12 Jul 2010How to Troubleshoot a CD Player - YouTubehttps://www.youtube.com/watch?v=xAlPb7NBvz4Search for: How do you fix a CD player that skips?
or try this link for more help if you need it.
cd player skips Google Search
SOURCE: My CD player keeps flashing (F15) when I try to play a disc.
It means that the laser/motor module is disconnected. Open the player and locate the connection band of the module. It should be orange, about 1 cm wide and it comes out from under it. Push it HARD into it\'s socket. Make sure you don\'t leave sweat or grease on the electronic and test it. I hope it works for you!
SOURCE: cd tray mechanics
It can be repaired but in all of my years in consumer repair, I dread the CD/DVD tray alignments the worst.
There are many things involved in getting them to operate without fail. Using the mfgs documentation you can get them up and running but most of the time they failed because something is amiss to begin with. So you spend an hour getting everything setup and it will work once or twice but them fail. Only to find out that a location sensor is bad or a gear is missing a tooth....
SOURCE: cd skips
If the unit continues to skip after cleanig the lens using a cotton swab and alcohol, the optics are failing and need to be replaced. These units use Sony optics (KSS-213C I think) and are readily available for $25 or so. Any service shop should be able to replace this for under $100 total.
Dan
SOURCE: CD player skips
Try cleaning the lens. If you can see the lens when you open it to put a cd in, you can clean the lens yourself with a q-tip. Use a very small amount of alcohol or windex, just enough to make the tip of the q-tip moist, and rub it on the glass lens in a circular motion. then use the dry end of the q-tip to dry it off. You can then try another cd and see if it plays good. If so, you are good to go, if not, you probably need a new laser pick up. If it needs a new laser, you may want to just buy a new boombox. The repair will most likely cost as much or more than a new boombox would.
If you are not able to see the lens and clean it yourself, try using a cleaning disc. They do not work as good, but they can help. You run it for about 20 seconds, or whatever the directions state. Then give it another try, see if it plays better.
Those are the only reasonable steps for an end user who is not experienced with repairing these type of units. anything else you may end up trying could just cause more damage to the unit, if you are not experienced with electronic repairs.
I hope this helps, let me know if you need more help.
Dave
SOURCE: numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
