1999 oldsmobile cutlass a/c problem light on the controller unit flashes and the a/c goes on and off
    President:
  • 1,922 Answers
Do you get cold or cool air?if not it sounds like your low on refrigerant,have a manifold gauge put on it and see what your pressures are,if low you can try to top it off to see if that helps, if not too bad leave it otherwise find the leak and fix it,pump the unit down and rechk for leaks,then recharge
Posted on Jul 30, 2009
Car will not start, a clicking whining noise. Lights flash, door lock no longer works
2001 Oldsmobile Alero Turns Over But Won't Start: 119 ...
www.carcomplaints.com/Oldsmobile/.../2001/.../turns_over_but_wont_st...
The 2001 Oldsmobile Alero has 119 complaints for turns over but won't start. ...Achieva · Aurora · Bravada · Calais · Cutlass · Cutlass Calais · Cutlass Ciera · Cutlass... We try giving it a jump, still does not start. .... oil sludge whining noise stalls while driving engine complaint electrical issue .... Mom my car wont start AGAIN.
Oldsmobile Forum Repair Questions- Newest Answers
www.greatautohelp.com/oldsmobile.php
Long story short the car will now start and idle when you step on the gas it will rev ....This whining noise seems to start when the engine temp goes above 200 degrees. ...hood from the outside on an 1999 oldsmobile aurora when i cant get in my car. .... My2001 Oldsmobile Aurora has had the battery disconnected due to a ...
Feb 08, 2016 | 2001 Oldsmobile Aurora
Fuse box diagram for 1998 oldsmobile cutlass
On this website you find fuse box diagram and description for Oldsmobile Cutlass (1997 - 1999)
Oldsmobile Cutlass 1997 1999 fuse box diagram Auto Genius
Aug 07, 2013 | 1998 Oldsmobile Cutlass
1999 oldsmobile cutlass's brake light and abs lighty stay on all the time
Sound like a problem with the wheel speed sensor, but to know exactly what is the wrong, you will need scanned the system to found fault codes. With this code number couls send details and tips to solve it.
Keep us updated.
Sep 21, 2011 | 1999 Oldsmobile Cutlass
What are the possible causes for code number p0410 on my 1999 oldsmobile cutlass?
Thats the code for "secondary air injection". Very hard to track down the source. Could be broken wire, rotton vacuum lines, bad "egr" valve, bad control unit (on backside of engine facing firewall).
If the engine light is on, try disconnecting the control unit on back of engine, passenger side connector. If the engine light is not on, I would not worry about it, unless you have lots of money to throw at it!!
Aug 23, 2011 | 1999 Oldsmobile Cutlass
What type of ignition does 1988 cutlass ceria 3.8l have 1 or 2 ?????
BOTH types of ignition coils were used on 1988 Cutlass Ciera. Type 1 is a single unit with 3 coils built into it. If one coil goes bad, you must replace the entire unit. Type 2 incorporates 3 separate coils mounted on the control module. These coils can be replaced individually. (See picture below) You simply have to LOOK at your ignition coils to see which type your Cutlass is equipped with. Please note that these systems are NOT interchangeable.
Jul 10, 2011 | 1988 Oldsmobile Cutlass Ciera
Fuel guage
sounds like a bad ground on the sending unit. hope ths helps mike
Jun 16, 2009 | 1999 Oldsmobile Cutlass
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
