Question about Weber Grilling
Weber Genisis = Problem is that gas tank is full but no gas is getting to the burners when on. I thought it was maybe the gas tank valve. I changed to another tank but had same problem. There is no kink in gas line and I cannot detect or smell aleak.
  • 57 Answers
Bad regulator replace it you can get it at home depot
Posted on Aug 25, 2009
Poor flame after changing tank on gas grille
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
Model Q200, Propane model Get no flame on the burner. Apparently, getting no gas. Something seems to be stopped up. What to do?
Whether you're using a 20 Lb Propane Grill Tank or a screw in gas canister, the solution to the problem is the same .
1. Be sure you have enough gas in the tank or canister to maintain proper ignition.
2, If the above checks out OK. Turn the LP tank valve OFF or if you're using a screw-on canister
turn the gas valve OFF.
3. Disconnect the hose from the tank or unscrew and remove the gas canister.
4. Wait 5 minutes and reconnect the hose to the tank or reattach the canister to the gas valve.
5. Open the gas valve VERY, VERY SLOWLY (Slow Motion, slow). Once the valve is full open, light
the burner & turn it to HIGH. Did the burner light and does the flame height look correct?
If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly.
if the above didn't solve the problem, you will either need to replace the Hose/Regulator Assembly or the Gas Valve/ Canister Holder. The Hose/Regulator Assembly you can pickup from any home center or hardware store that sell grills & accessories for about $30.00. If it's the Gas Valve/Canister Holder, you will have to purchase that from Weber or from Factory Appliance Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/weber/q200.html Part # WEB4195 ($29.99) The adapter hose is also available there if you want to make it a one stop shop for $32.99
I hope ths helped you and thanks for choosing FixYa. Happy Grilling!!
Aug 26, 2011 | Weber Q Grill
The line from the gas source seems to be plugged on the weber. the gas does not seem to coming through. The weber worked fine last night.
there is sometimes an automatic shutoff if too much flow is detected. Occasionally when the lines are purged and you open the valve on the tank it will activate this.
  1. turn the tank off
  2. turn the burners on
  3. wait 10 seconds and turn the burners off
  4. open tank valve slowly- listen for a slight ping or click, if this happens that is the shut off activating, try again opening the valve more slowly.
Hope this helps, also make sure tank is full and you didn't leave it on all night. If this helps please rate it
Jul 05, 2011 | Weber Grilling
Weber grill has been performing inconsistently. It does not heat up above 250 degrees and frequently the flames go out. It's a Genisis B two burner grill
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Grill won't ignite. full tank, wires look OK. model is the second smallest weber Q.
If you're not getting any gas at all to the burner and you have a full tank pf LPG ... Turn the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Now, turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the tank valve is fully open try lighting the burner. If lights, turn it up to the highest setting. Does the flame height look correct? If so, you solved the problem. Just remember to always turn the tank valve on VERY, VERY SLOWLY.
If you were getting gas to the burner and the ignitor wasn't sparking, pull the wire of the needle like pin on the bottom of the piezo spark ignitor. Then slide it back On. That should solve the sparkless problem.
Hope this helped you solve the problem.
Apr 04, 2011 | Weber Grilling
I thoroughly cleaned my Weber Genesis Silver A and have a full tank of gas. It won't get hotter than 250-300 degrees. Flames are blue.
You might have air block. When turning off the grill, leave one burner on and shut the tank valve.
When grill cools, close the remaining valve. When restarting the grill, open the tank valve, then the start burner, then the igniter. When first burner is going, open remaining two valves to preheat the grill.
This has worked on two different grills.
Dec 30, 2010 | Weber Genesis Silver A Grill
Two things....I changed the tanks out last night and I can't get the burners to light. Full tank of gas as I checked it. Took the burner covers off and cleaned the burner pipes itself and still nothing? ...
Replace the regulator to get your burners to work you can get that at Home Depot, call Weber to get the other part, if your grill is under warranty you may get it Free!
Aug 15, 2010 | Weber Genesis E-310 Gas Grill
Gas is not moving from tank to Weber silver grill
  1. you need to shut off all the valves and disconnect the tank.
  2. slowly open the tank valve and listen for gas escaping. (DO NOT ATTEMPT TO SMELL FOR THE GAS, THIS COULD PROVE HARMFUL TO YOUR HEALTH)
  3. you are looking for a valve or connection that is clogged. if gas escapes from the tank the reconnect the tank and check at each connection.
  4. if all connections are complete and functional, your problem may be at the burner itself. Using a push pin, **** the holes in the burner, paying attention to the amount of greasy build up.
  5. If the level of build up is severe, remove the burners completely and soak them in a tub of concentrated dish soap and warm water. DO not use hot or cold water.
  6. remember to shut the tank valve off in between each test cycle.
  7. a clean grill is the key to keeping it functioning properly,
  8. if you are having trouble getting the burners out, spray lighter fluid on the burners holes and light with a fireplace match, or rolled piece of paper.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
May 03, 2010 | Weber Genesis Silver C Grill
Can't get a flame
Unscrew the fitting off the tank and make sure there isn't an extra washer in there. Sometimes when you get a tank there will be a washer inside it that has slid of the last guys POL(screw in hickey) With this extra washer, the POL isn't going in far enough to open the tank valve.
Sep 08, 2009 | Weber Summit E-620 Gas Grill
Weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Mar 23, 2009 | Weber Genesis Silver C Grill
Grilling Logo
116 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
